mechanical transmission to electrical speedometer
Old Dec 25, 2008 | 12:22 AM
arctic white 94's Avatar
Default mechanical transmission to electrical speedometer
I am about to start swapping a first generation sbc into a 95 camaro. I will probably run some sort of manual non electronic transmission. I might just go with a th400 or 700r. Is it possible to get the stock speedometer to work correctly with this setup? I know you can get the signal from the abs but since the engine will not be using it can I still run it through the pcm to tune it and it function correctly? I know you can also get a reluctor wheel and speed sensor but that wouldnt have the correct signal either. Ive done alot of searching but I have not found a definite answer yet. If anyone has any advice on how to make this work it will be greatly appreciated.
Old Dec 29, 2008 | 06:13 PM
Does anyone know?
Old Dec 29, 2008 | 08:22 PM
tptransmission's Avatar
Closed ex-Sponsor Account
If it is a 700r4 you are going with, you can use the same reluctor wheel as a 4l60e. Also there are converters that can change mechanical signal to electric and vice versa.
Old Dec 30, 2008 | 01:40 AM
9000th01ss's Avatar
If you go with a th400 there are factory truck applications that use a reluctor wheel and electric sender.
Old Dec 31, 2008 | 08:23 PM
Does the signal have to go through the pcm? Could I just use the pcm to drive the speedometer even if it is not running the engine?
Thanks for helping.
Old Jan 1, 2009 | 11:19 AM
Thanks for helping.
You can if you want too. If it has the right cal for want ratios you are using just keep the power and ground going to it.
Old Jan 1, 2009 | 06:03 PM
That would probably be the cheapest way to do it wouldnt it?
Old Jan 1, 2009 | 06:18 PM
9000th01ss's Avatar
I've done it like that on a '88 GMC truck, '89 Silverado, and '93 Silverado. Slightly different but same theory.
Usually cut a ton of wires out as well, and kept the ones needed.
Old Jan 1, 2009 | 07:23 PM
Do you know where I could find a wiring diagram to show what wires I need to keep.
Thanks
Old Jan 1, 2009 | 10:17 PM
What year is your car or what type controller is it?
Old Jan 1, 2009 | 10:21 PM
Never mind I read the beginning. Stay tuned.
