check engine light on and stuck in 3rd?
Old Dec 30, 2008 | 05:21 AM
blwn_00gt's Avatar
Default check engine light on and stuck in 3rd?
so im coming home from work this morning and the check engine light comes on and then i notice that the converter doesnt want to lock up anymore, now when i get to my house and open the garage door the car doesnt want to move, its like it is stuck in third gear or something. i guess ill go get it scaned as soon as something is open but im kinda wondering what has happend to the tranny. anyone have any ideal..thanks
Old Dec 30, 2008 | 06:46 AM
FLT's Avatar
FLT
The third gear start is a limp mode condition usually caused by a transmission code. I would do as you have planned and get it scanned. Have you recently done anything with the transmission like a stall converter? Vince
Old Dec 30, 2008 | 09:48 AM
blwn_00gt's Avatar
yea i have a 3200 vig but its been in there for a little while now.
Old Dec 30, 2008 | 09:51 AM
performabuilt's Avatar
LS1Tech Sponsor
I would get the codes ASAP and make sure and get the number not just what they mean, And post them here
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 30, 2008 | 11:39 AM
blwn_00gt's Avatar
ok the code is P0757 and it say that the shift solenoid b circuit is stuck on..wth
Old Dec 30, 2008 | 11:44 AM
tptransmission's Avatar
Closed ex-Sponsor Account
If the fluid is not burnt you may want do some electrical checks on both solenoids. You could get lucky and just have an electrical problem (if you call that luck).
Old Dec 30, 2008 | 12:07 PM
blwn_00gt's Avatar
well i just cleared the code and drove it down the road and now its fine. so now what should i do?
Old Dec 30, 2008 | 12:17 PM
t_raven's Avatar
Drive it and see if it comes back lol
Old Dec 30, 2008 | 12:18 PM
JonCR96Z's Avatar
Have the code turned off with a tune. It's not uncommon to get that code with a big stall.
Old Dec 30, 2008 | 12:22 PM
blwn_00gt's Avatar
yea i just got off the phone with nick williams and im going over there now to have him turn them off and see if that helps.
Old Dec 30, 2008 | 12:31 PM
LS1Tech Sponsor
Well with that stall that code should have been turned out when th car was tuned for it , Since it went away I would guest its just a fluke that is caused by the stall. Have your tuner remove the test for it and you should be fine,
I realize you have had the stall a while but i have seen this happen a few times and who knows it may not happen again
__________________
Call 888-744-6542
Old Dec 30, 2008 | 02:48 PM
blwn_00gt's Avatar
ok i we have removed the code now so im going to ride it around and see what happens..
