What STR do I want?
the stall speed and diameter you want.
I think you will have zero traction in 1st gear regardless
of what you choose. This is one reason I went with a low
STR on my build (3.42s).
The two things a low STR will give you are a better fluid
coupling at low slip (I cruise at 1500RPM at 30MPH in 3rd,
climb grades at 2000RPM on a 3500/2.0 converter) and a
broader range of torque multiplication. A higher STR has
less RPM between paddlewheeling and fully coupled. In
my opinion a low STR is more street friendly, thrust is
pedal-proportional.
But I don' tknow if this enters into it, 3800+ is not what
I'd pick for the street.
How are you planning to hook up 3.73s and a (say) 2.5:1
multiplication off the line? I've been unable on 3 brands of
regular tire and ET Streets. Spin all through 1st and the
lower half of 2nd, with less gear and less (2.0) STR.
Greg
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Greg
1-866-726-8358
FTIPerformance.com
