Thoughts on this flexplate
Old Jan 5, 2009 | 07:52 PM
Intercooler2's Avatar
Default Thoughts on this flexplate
I didn't realize how many stockers had failed until I did a search here. I'm getting ready to do a converter so looking at prices and it goes from $132-$450 for and SFI. But on E-Bay we have this one for $60.00 SFI approved:
http://cgi.ebay.com/ebaymotors/GM-LS...Q5fAccessories
All the features of the others.
Old Jan 5, 2009 | 08:02 PM
More info:
LS1 SBC SMALL BLOCK CHEVY
SFI FLEXPLATE
This auction is for a Hawks Racing SFI Flexplate for LS Series Small Block Chevrolet's. LS1 LS6 Chevy's. This unit is brand new in the box and is in PERFECT OPERATING CONDITION !!!! This unit fits all SB LS1 LS6 Chevy's 97- current, and is INTERNAL BALANCE with a 168 tooth gear. (Bidder is responsible for researching fitment) This is the flex plate you need to comply with NHRA/NMCA etc. rules!!
Check out these value added Features!!
.138" Thick Cold Roll Carbon Steel Plate (stock is .075)
Double Welded on Both Sides of the 168 tooth ring gear
Internally Balance to OEM Specs
14.09" OD
1997-2006
Long Lasting Rust Proof Zinc finish
SFI Compliant 29.1 (12,500RPM!)
NHRA Legal
Hawks Racing? Anyone?
That's the maker
Old Jan 5, 2009 | 11:27 PM
cals400ex's Avatar
i wouldn't get a cheap one. i went all out and got a meziere. i didn't want one that would break and i wasn't sure if the cheaper ones were balanced well. i am sure you would get vibration if it wasn't. i think speed inc makes one. you could also get a gm replacement but these are not sfi rated.
Old Jan 6, 2009 | 05:17 AM
Well you don't have to spend $400 either. From researching I found info saying this is the same flexplate as B&M. Prices are all over the place on these things.
Old Jan 6, 2009 | 01:22 PM
Guess I am the test mule.... ordered that flywheel. I will post up pics with measurements and all. Won't be the first time... bought the Summit Racing SFI underdrive and real happy with it.
Old Jan 7, 2009 | 09:20 AM
Found a member here who is using the Hawk Racing flexplate and got his testimonial. The member is SuperSport01LS6:
Hawks Racing flexplate
Yes I did end up installing one. In my opinion it was great quality it was thicker then stock it had more welds around the entire circumference on both sides. and for the price you cant beat it. My best time to date is only 12.1 @ 115 but thats just a mild cam and milled heads with a 1.79 sixty. Still on the stock 10 bolt so i dont wanna push it and my converter is a tight 3500 stall from PTC but overall when i bought it I was very happy!
I received a FedEx tracker yesterday and it will be here in 3 days which is great. I will measure and photo it when I get it.
Old Jan 10, 2009 | 11:11 AM
I got it! As can be seen SFI 29.1 rated with cert. Also no powdercoating that needs stripped and the ring gear is welded both sides. Ring gear width measures .430" wide and plate thickness where the flywheel and converter bolt measure .155" thick. I don't have a early 98 flywheel to put up comparison numbers but when I get my 02 out I will add it. If anyone cares to add numbers of stock pieces feel free!
Old Jan 10, 2009 | 11:14 AM
Pics:
Attached Thumbnails Thoughts on this flexplate-img_0187.jpg   Thoughts on this flexplate-img_0189.jpg   Thoughts on this flexplate-img_0191.jpg   Thoughts on this flexplate-img_0192.jpg
Old Jan 11, 2009 | 03:46 AM
johnLs1camaro's Avatar
hey man i bought that flexplate, i have had no issues with it. i also know other members that are happy with it too. i did have to drill the holes for the converterbolts, because my bolts werent fitting in that well. otherwise its a very good flexplate for the money.
Old Jan 11, 2009 | 11:35 AM
9sec93's Avatar
it is kinda funny though when they mis-spell parts on the main label in the first pic. "Power Engine Pares" hahaha. i hope quality control for the part is better than the quality control for the label.
Old Mar 3, 2009 | 03:03 PM
patriotformula's Avatar
Anyone run this flexplate with a th400 or a th350? Does it need that spacer plate in it or not?
Old Mar 3, 2009 | 03:36 PM
9sec93's Avatar
if the converter was made for an LS1 than you wont need anything. if it is made for a standard sbc than you will need the little round adapter to center the converter in the crank. and will also probably have to open up the holes a bit where the converter bolts to the flexplate.
Old Mar 3, 2009 | 07:47 PM
5_02ls1's Avatar
Default your stock one
you should sell me your stock one if its in good shape.........
Old Mar 5, 2009 | 01:38 PM
Okay. PM me... in good shape!
Old May 3, 2009 | 04:13 PM
tording99Z28's Avatar
Those of you that are running this ebay flexplate what bolts did you need to bolt the converter to the flexplate? I am running a Yank converter, will the bolts that Yank supplied me work with this flexplate or not?
Old May 3, 2009 | 07:26 PM
yeah, you will just have to drill the bolt holes out a just a little bit, or atleast i had to.
Old May 4, 2009 | 06:53 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
You should look at our billet aluminum flexplate w/ bolt on ring gear.It has all three bolt circles and is SFI approved. Heres some pics.
They are still os sale for 250.00
Greg
1-866-726-8358
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Jul 28, 2009 | 01:58 PM
01ssreda4's Avatar
op any update on the long-term??
Old Jul 28, 2009 | 05:41 PM
Giddswat's Avatar
Pics:
I have the same one and it works fine. The CAT flex plate .
Old Jul 28, 2009 | 06:05 PM
383lt1impala's Avatar
Did any of u guys use the hughes spacer? Did u have to use washers between the flexplate and the converter?
