trans cooler location with APS TT
The aps kit takes up any location on the front that I could mount the cooler.
I am thinking about putting the cooler in the trunk in the spare tire space. Would that be a good location for the performance of the cooler. It does have a big fan on it, so Im mot worried about air flow.
Just trying to figure out where to put it
any suggestions or comments?
I will have to look around at the rear and see if it will mount anywhere back there
Yep it is in the passenger side wheel well. I do not have a fan on mine (though it would definitely benefit). I removed the wheel well and my fiance made some brackets to hold the cooler. Then we used braided lines to run it to the trans/etc. I cut a big hole out of the wheel well, reinstalled, and you don't even really see it unless you are looking for it.
I have not had any problems with it overheating.
mounted his up in the rear axle arch with a couple
(?) of muffin fans. Probably about the same run of
tubing, but no dumping trans heat into the radiator
air stream.
