PT4000 owners.. need some advice
My converter is showing about 14% slip running through the traps. I know it will be less with more gear (which I plan on 3.73s soon), but does that sound about on par with stock weight and 3.23 gears? This is supposed to be their "most efficient, baddest converter" they have for NA. This is with a new FLT 4 trans and the converter was just gone through by Yank.
This appears to be on par with what another member was noticing with his PT4400 (13% IIRC). I've seen lower figures as well, but I've never had the opportunity to check mine. I'd see what it is once you add the gears, and if you're not satisfied, look into a different converter.
On a side note, I'd be interested to see what the efficiency is on other large converters for comparison sake.
Thats on par with mine 13%.It pulls really hard but one of its atributes is high amount of slippage.I dont think it will change much(percent ) with a gear change,i have 4.11 gears.You might try hooking up a switch so that you can lock up the verter in high gear,i never tried it(probably should have).
Is 13% acceptable???
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Yank has threw out the number 5% to me more than once on the PT series.
Hawk I see you always talking good stuff on the Yank which is fine. And you have track numbers i see. Why is it that you've never done some figuring before?
I'm going through the traps at 5750 rpm. Peak power is ~6700 rpm. Shift points are 6900. Rev limiter is 7200
Last edited by frito1; 03-08-2009 at 03:48 PM. Reason: bad proof reading on my part
I don't have ready access to tuning software, and to be honest I'd never thought about it before. Putting this in was a huge improvement over my last converter and I was very pleased with its performance. If I get the opportunity, I will calculate mine, but it will most likely be awhile. I'm not convinced at this point that the gains, if any, would justify the cost and hassle of doing a converter swap. I'm doing the research, but at this point I'll stick with what I've got.
MPH will go a little!
But the difference of a few percent in third gear for about a second is really not very much in ET Loss or MPH gain
Of course every bit helps if you are looking for a ET drop or MPH gain just dont expect a lot.
To check the converter slip you must use second gear as it will reflect the true converter slip %
Here's a dandy little calculator for figuring different stuff with. It's about the 5th one down....
http://www.tciauto.com/Products/Tech...culators.asp#4
I don't use tuning software to figure my converter slip going through the traps. I use my time slip for the mph, rpm right at the finish line (stock tach is questionable, that's where I use the tuning data log), tire height, rear gears, and trans ratio is 1.00 in 3rd gear.
Sweet, didn't know it was that easy. Everyone I have seen post about calculating slip always talked about data logs. I'll see what I can come up with.
Yes you log you mph,tire height,engine rpm, rear gear ratio.My car the stock tach in high gear hangs around 5500 and never moves.(real pice of crap)Now on my auto tap logs it shifts from 2-3 at 6800 and drops to 6100 and climbs to 6700-6800 before crossing the finnish line.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Using that calculator, time slips and datalogs I calculated 11% slippage for my old PT4000 and 7% for my Circle D 5C. I see about the same difference when driving around town. Rear gears are 3.73.
