Torque converter.Is a cam neccesary
Old Oct 20, 2003 | 05:03 AM
LS1FIRE's Avatar
Default Torque converter.Is a cam neccesary
Hello i own 1998 pontiac trans -am A4.I am instread in purchasing a toruqe converter.But a person told me that it is not neccasery to go with a after maket torque converter unless i get a cam shaft.Is that true?
Old Oct 20, 2003 | 05:07 AM
Nagash01WS6's Avatar
Default Re: Torque converter.Is a cam neccesary
NO!!!!!!!
Torque converters are great even with a stock motor. They will still give you gains of up to .5 in the quarter.
A Torque Converter should be every automatic ls1 drivers first mod!!!!! The converter will give you the ability to run a large cam when you want to go internal engine however.
Old Oct 20, 2003 | 06:30 AM
2001 Pewter WS6's Avatar
Restricted User
Not necessary... I ran a 12.02@111 with a 1.60 60' with the stock motor and a Vig3200. You will think you have a different car with a converter in there. When I did add a small cam, it ran a 11.70@115 with the full interior.
Old Oct 20, 2003 | 08:39 AM
DEEZ98Z's Avatar
A TC should be on of the first mods you do as an A4 owner
Old Oct 20, 2003 | 09:26 AM
WILWAXU's Avatar
Converter will make more difference than a Cam.
Old Oct 20, 2003 | 08:07 PM
onebadz's Avatar
Yea man this should defiantly be every A4s first mod, you should check out Thunder Racing they have many Torque Converters to choose from, they are a sponsor. Also you might want to do some research on TCI, and Yank's sights. They are listed in the sponsors. ---->
Old Oct 20, 2003 | 08:32 PM
cyphur's Avatar
d0000000d!!!! should be your first mod!! a nice 3200-3600 and you'll be G2G!!! Plus like all these knowledge-laden fellas that have said before me....it will still keep helping as you keep modding...
Old Oct 20, 2003 | 08:36 PM
onebadz's Avatar
If you do decide to get a TC you will need a Tranny cooler and a shift kit (TCI or TransGo work fine). I got my whole setup from TR for just under 722 bucks. Good luck man.
Old Oct 21, 2003 | 02:33 AM
I prefer the Yank converters. Ive run a Precision 3200, Midwest 3700, Yank ST3500, and now a Yank SS3800. Out of all of them the Yank felt like it pulled the hardest up top, and I got the best ET's out of the Yank. I would definately stick with a name brand converter after seeing the TCS thread up top.
Old Oct 21, 2003 | 02:51 AM
42NightZ28's Avatar
also get a trans temp gauge, i cooked my first trans becasue i got to happy with the throttle.
Old Oct 23, 2003 | 05:08 AM
4thGENRETARD's Avatar
Definitly a cooler but shift kit is not necessary as long as you increase line pressure depending on your str.
Old Oct 24, 2003 | 07:17 AM
Ed Blown Vert's Avatar
Yep.
Old Oct 24, 2003 | 12:09 PM
Originally Posted by Ed LS1 Vert
Yep.
DITTO, TC's are
Old Oct 25, 2003 | 09:18 AM
onebadz's Avatar
Actually man, you do need a shift kit, unless you manually increase your line pressure, if you are tallking about increasing the pressure with a programmer its not actually increasing it, it is just specifing a later point when that pressure is released. If you dont get one your verter will feel really loose and your shifts will be very soft.
Old Oct 25, 2003 | 09:47 AM
waterbug1999's Avatar
How does it drive on the street? I mean as a daily driver situation?
Old Oct 27, 2003 | 11:00 PM
WILWAXU's Avatar
My Formula was my only form of transportation till last year, and still gets driven in all but the worst weather. It's had a 4200 or higher stall in it since it was 3 months old (3 years)
Old Oct 29, 2003 | 10:33 PM
2000WS6Vert's Avatar
This is my question. How sluggish does the car feel if you're driving through a parking lot...say 2-25 mph. Does the car rev really high and feel like it's not going anywhere?
Why does a converter make such a difference?
How much will my top end suffer?
