Anybody got a tune with 4L80E os merged with a f-body hptuner file
Here's mine. Just as a point to consider if this doesn't work for you, when Bill at HP Tuners was helping me out with the segmenting of the operating system, he said that the OS numbers had to match between the donor PCM and the receiving PCM or a segmentation could not be done. Maybe since it's already been done here, if you perform a "write entire" (which had to be done once my tune was segmented) it won't matter and will work for you. I'm obviously no tuning expert!
P.S.
This was before anything was adjusted fro the new tranny, so you're gonna have to tweak it to suit your needs.
P.S.
Gingervitis Addict ![](http://s24.postimg.org/5ong4sl1t/Gingervitis2.jpg)
P.S.
P.S.
Why did you swap the 80 segment into an M6 file instead of an A4? Does it work? Things like your gearing and M6 spark smoothing are still enabled
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Guessing anyone else could do the same.
That's what I got back from HP Tuners. I did change a bunch of things since I flashed my PCM with the OS, but to be honest, I really haven't looked at the file all that closely. I finished the swap then got seriously injured (hit by a car and shattered my legs) and took the car off the road. I've been unable to drive for the last 10 months and it looks like I won't be back in the saddle for at least another six if I can even afford to keep the car by that point.
