Yank SS3600 or SS4000??
I can't make up my mind and would like any advice from people who have one or both of these.
Car:
2000 z28 Full weight car
12 bolt (has 3.73 and can swap in 4.10 if better)
full bolt ons
Motor:6.0L LQ9 with heads/cam
shift rpm will be 6500-6700 rpm (still picking cam)
*** I am contemplating hitting it with just a 100 shot, but won't be for a while**
Car will be a toy. Drive to cruise nights, to work once in a while, drag strip 3-5 times a year, beat on it hard on the street. Will still have good suspension for ripping corners and stuff too.
Concern is that SS4000 is too high for street driving AND would not work well with 100 Shot. Not sure if 3600 will be enough.
Thanks!
Car:
full bolt ons
Thanks!
Give Dave a call Im sure he'd be more than happy to talk it over with ya. I say go for the 4000 for your setup. I just put in the py3600 in mine and it drives like stock until you hammer it.
I just talked to him and he said that the 3600 would drop back to ~51-5200 rpm on the shifts and the 4000 would be around 5500 rpm or so. I am not sure if the new motor will be stought enough to only operate in a window of 5500-6500???? Still have to put the motor together, so I don't have any solid data yet.....
dropping down to 5200 shouldn't be too bad since it will only be about 25 hp or so below peak.
What RPM are you shifting at? What RPM is is at when it drops back into gear on a shift? Do you remember where it was on the SS3600 compared to now? My race weight will be a little heavier than yours.... Was 3783 with LS1 Alum 383 and M6, now will have Iron 6.0L and A4. It aint me being heavy either.... I am only 175#
I am still trying to find someone local so I can see how it is in person.
thanks
thanks
thanks
you are more than welcome to stop by the house and I will take you for a drive in the z28 I am always open to meet more people…
Yeah I know I should have just gotten mine restalled when I had it I don’t know what I was thinking…well now we both have the ss4000’s…I will let you know how she performs probably wont be for a year or so though…gotten get the 12 bolt and heads first…or maybe I will spray her cam only…
i really cant remember what the shift extension is on either i can run a log when i get my rear back together this weekend for you, but i wanna say it was around 1200rpm drop...my shift points are at 6800 so it drops to around 5600...i will make sure dont quote me on that …
Where you located?
thanks
SS4000 hands down with your setup. With the 3.73's it'll be nice and tight for the street, but still give you some great performance. I ran one and liked it, but I wanted more of an all motor converter which is why I swapped to the PT4400. SS4000 is arguably the best converter for a street/strip car!
Yeah I launch it the same way as the ss3600 did…brake stall it up as high as it will go before it starts pushing through the front brakes, and then roll off the brake and into the gas at the same time, that is what has always worked best for both on my ss series stalls, flashing it gave around .1 higher 60fts…plus like you said the brake stall preloads the chassis so there is less unloading from the stock of initial hit…
You guys think I will be able to hook on a 26x11.5x16 Mickey ET Street?
Dumping the clutch at 6000 rpm with the M6 would get me a 1.63 60'.
I was hoping with the A4 and the stall it would drop the 60' and not shock the drivetrain as much. I would get a little bit of a spin before, but SOMETHING has to give on the M6, so better to spin a little than break stuff..... I have been through a few clutches, a drive shaft, and a rear end.... Its all bullet proof now!
