2-3 Shift Solenoid?
2-3 Shift Solenoid?
I've been having problems with my 2-3 shifts at WOT, could it be the 2-3 shift solenoid? Where exactly is it and where can I get a new one? Tranny is brand new and TC has been refreshened, this has been happening before the new tranny.
Check it with ATAP, if it is the 2-3 solenoid you should be getting a code. Do you have custom tuning? It could be the MPH or RPM shift settings. Is it hanging between shifts?
There is no 2-3 shift solenoid in the 4L60E. There is an "A" and a "B" shift solenoid. Here is how they work together to change gears.
1st gear, "A" on; "B" on.
2nd gear, "A" off; "B" on.
3rd gear, "A" off; "B" off.
4th/OD, "A" on; "B"off.
Since "A" is already off in 2, if there is a solenoid related shift problem, it has to be "B". You should see something like 'P0755'; "Shift Solenoid B Malfunction". 'P0757'; "Shift Solenoid B Stuck On" or 'P0758';"Shift Solenoid B Electrical".
Get a scanner/diagnosis from a good shop. These trannys are far too complex to 'bench diagnose'. And you can waste a bunch of money replacing 'this and that' and still not cure the problem.
does it just contin ue to rev in 2nd until it hits the rev limiter? if so it could be burnt 3/4 clutchpack. that happened to my car my first wot run after getting my tranny rebuilt the first time
remeber with a converter you will get spongy shifts on a internaly stock a4 --my car shifted real hard from the factory --lost it when i put a 3500 stall in -- most likely nothing wrong with the tranny --try a billet servo
Could it be the fuel pump or fuel filter? This has been going on before the new tranny, and I'm not throwing any codes. Before the new tranny I kept blowing the 3-4 clutches every month for the last 5 months, that's why I got a new tranny. What kept the tranny from doing this, besides that, the shop told me that the input drum was totally fried, I don't know what else to try. Tranny shops down here really suck.
did you ever flush your radiator--there may have been metal in the radiator from the fried drum -and band material- OH make sure that plug on the right side of the tranny is in tight --that happened to me i had the same symptoms you explaind - big grey one with the arrow molded on it
Moderator
PCM is partly to blame for commanding slow-***
soft shifting. Get it programmed (if it already
hasn't sanded itself smooth from all that
weak apply under power) and you'll see a
real difference in behavior.
Note that at part throttle your GMAF may be
causing the PCM to think it's under less load
and needs less apply pressure and can stand
a more leisurely shift.
