4l80e fourth gen f body swap guys with aftermarket pans
Anyone running aftermarket 4l80 pans from tci, derale ,etc and if so how is your ground clearance? Is your car at stock height or lowered.
I am running stock height and thining to put a different pan on my car .Most seem to be a fair bit deeper than stock.
So would like to hear from some of you guys that are running aftermarket pans.
if you want the extra cooling/capacity of a deep pan, I suggest a larger trans cooler before that. the larger cooler will have the same effect and not cause you any ground clearance issues. if your trans is still gettin hot, then add a fan to your trans cooler.
but, I have looked into it, and I could run a deeper pan on my 94 w/4l80E without having issues with ground clearance. however, you dont want to have to worry about it all the time when driving, do you?
EDIt: my car is lowered 1.5, and my engine configuration/placement is also lower than LSx/Ltx engines.
Gingervitis Addict ![](http://s24.postimg.org/5ong4sl1t/Gingervitis2.jpg)
I have a pretty loose 3500 stall/3.00 gears. I do have a fan on the cooler, but still haven't hooked it up since it runs pretty cool.
The following users liked this post:
rimfire27 (09-28-2019)
I have some space issues on my car with the turbos and all that so am thinking to run thru my ron davis rad and into auxillary cooler. I have put a big dual pass 24 inch tubular type behind my air dam and might drill some cooling holes in the dam to give it a bit more airflow. By itself ,no rad cooler, it don't seem to be doing that great. Also since do drive the car at colder times of year in spring and fall felt likely good idea to go thru the rad as well.
The pan would be one more thing that could do depending on how the rad and auxillary work.So far seems all the aftermarket pans are deep style and most quite a bit deeper .
I do think rossler maybe has modifed one with big more clearance that think uses for his transbrake.
I do think rossler maybe has modifed one with big more clearance that think uses for his transbrake.[/QUOTE]
I just recieved my trans pan from rossler that is modified for his trans brake yesterday i can grab a few measurements later tonight if u want its the modified moroso pan
The moroso pan is deep and the notch is nice but no cooling fins on it and no cooling tubes like the derale so can't really see how it would do much for cooling. A bit more capacity would do a bit I guess.
And yeah that don't look like enough cooler if thats the only way and in that location can't see it getting that much airflow really.
I will see how it goes with the ron davis rad with built in cooler and the aux on my car. I will hold off on getting a pan until that is done. It would be nice if few companies would offer a lower profile but at least finned cast aluminum pan. The deep ones might be ok but I like all the ground clearance I can get even with my car close to stock height. Thin the iron block and turbo kit weight brings it down some from stock.
But our roads suck bad here so ground clearance is a good thing.
i use the car quite often. it has been parked through the winter i pulled the engine and trans for a refresh. engine was in real good shape, trans has some concerns which will be a separate post to explain what was found after two years at 1200hp and what we did to prep it for 1400hp
when it is together as in the past it certainly does get used!
no i dont run it through my rad, as said the rad is 180* give or take and i prefer my trans temp always be below that.
this cooler is mounted ahead of the radiator offset to one side
Thanks, MS
