bigger tranny pan for lowered cars
car's lowered (prokit) is there a after market tranny pan that wont cause me to have issues with it scrapping??
or a pan that is the same as stock that has some sort of way to keep the tranny running cooler??
thanks
thanks
This pan would be a factory pan for a pickup. Get ot from either a dealer or salvage yard. I think they are like $25 new from a dealer. Just make sure to get a matching filter and gasket kit because the fluid pickup will be lower.
You can search this forum and you should find some info on using truck deep pans.
I have a bigger cooler w/fan & deeper pan. My car is not lowered and I have to be very careful of what I drive over..I may end up putting my stock pan back on.
dave
dave
Moderator
I stepped back from the TCI finned super-deep pan to the
truck pan because I was collecting too much yellow paint
on the drain plug. Truck pan is not the lowest thing in the
undercarriage and if you do tag it, it's steel and can take
some abuse. '02 Silverado is a good app to reference if
you want the drain plug.
Rossler offers an exclusive moroso fabbed pan. Pretty sure it holds about two extra quarts. Clearance looks good as well. And on the topic of added fluid, there is usually always a temperature reduction from this. It may not be 20 degrees(closer to 10) but this added benefit is only adding longevity.
so ineed an 02 silverado truck oil pan with the filter and the gasket right?? all from the dealer ???
also will i still be able to use my dip stick to check the fluid??
I have one of their "Cooler Pans" on my Formula for 2 years now. Adds 2 qts. has drain plug. You can get it for approx $70 give or take a fin ($5)
No problems. I'd recco it to anyone.
http://www.derale.com/
part # 14104 & 14204 (new #)
do a google search on "Derale 4l60e trans pan" for best price quotes.
