Upgraded my drive shaft.... again! The right way this time!!!
Originally I had the driveshaft shop 1000hp 200mph one piece (great driveshaft) then when I recently converted the car from M6 to 4L80E it required a different DS. I opted for another, it didn't play nice with other parts. And only lasted 300 miles, and instead of spending another $775 to fix that drive shaft, I decided to upgrade and do it right this time, so..........
Thomas aka Hendrix-Engineering in my best super hero voice..."TO THE RESCUE"
Thomas sent me his two piece chromoly / aluminum drive shaft with his new awesome one piece STEEL rear yoke with built in pinion seal protector (just as Holden also though it was important)! Two piece for the win. I guess there really is a reason that Holden did it this way, and Thomas just took it to the next level by improving it!
The yoke is incredible, it has an area recessed to allow for the ds flange to set inside to align it.
Another amazing product from Hendrix-Engineering.
Nice work Tom good to see your sorting it all out,lm also running 2 piece on the Monaro but the rubber donought has been removed changed the flange on the diff to VS commodore works great.How do you like your 4l80e, traction holding up better after minnitub.
CHEERS
JOE
CHEERS
JOE
CHEERS
JOE
CHEERS
JOE
Tom
Not sure it's needed, but I like to keep an idea ready, just in case!
Tom
:Tom,good news about your cooling for the trans l went custom built front cooler for the trans its ok winter here summer might be different story.Im always logged on with PLX guage which is good to know runs 185 havent driven long trips really to test her out.
Good to hear from you Tom
JOE
JOE
