'70 Chevelle TH350 problem, refuses to burnout?
Old Oct 22, 2010 | 11:39 PM
branj70's Avatar
Default '70 Chevelle TH350 problem, refuses to burnout?
I've got a built 350ci backed by a TH350. Now just recently ive noticed that if i floor it, the motor revs around 3k and doesnt really do much. It never revs higher than that while driving.
Also when i try to burnout recently, the whole front of the car torques like hell, but the tires wont turn anymore. But this only happens every once and a while, other times, i can lay a mean patch. The rear is a 10 bolt, 2.56 highway gear (****), im planning on upgrading the rear because they alone dont let the car rev very high, but im pretty sure they aren't causing me to be able to burn rubber, then next day not burn ****, and that even when foot braking!.
What could be the problem?
Old Oct 23, 2010 | 05:17 PM
Jays_SSZ28's Avatar
I built a th350 for a kid I used to work with.
He brought it back because his piece of **** wouldn't power brake, he burned up the forward clutches trying.
A week or two he brought it back again, I forgot why, but the low roller was broken.
A few weeks later he confessed to neutral dropping it to try to get it to burn out.
Thats what the future of your transmission is looking like.
Make the engine run right, change the rear gears. Might as well build the trans since it's already taken a beating.
Old Oct 23, 2010 | 09:31 PM
branj70's Avatar
But the trans still moves the car alright, it just ... lost its *****. lol
So could it be the forward clutches? I've never neutral dropped it, im not stupid. What exactly does the low roller do? And if it were the forward clutches, would it still drive?
Old Oct 23, 2010 | 10:01 PM
slow67's Avatar
Gingervitis Addict
If it were the forwards, the transmission would slip trying to go forward in all forward gears (if it even moved forward at all).
What gear was the shifter in when you tried it?
Old Oct 24, 2010 | 11:46 PM
branj70's Avatar
3 or drive. I never used 1 or 2, its always been 3
Old Jan 3, 2011 | 02:55 AM
branj70's Avatar
old post but BUMP because i still have the problem
Old Jan 3, 2011 | 11:22 AM
forcd ind's Avatar
2.56 gears, and if a cam low end torq not as much, = hit or miss
Old Jan 3, 2011 | 02:01 PM
branj70's Avatar
Ok so i still might have a chance at having at good tranny? I have a 3.32 rear being rebuilt right now, so hopefully it'll be in around spring.
Old Jan 3, 2011 | 02:31 PM
1981TA's Avatar
I have an early 70s TH350 coupled to a 3.23 10-bolt, and had trouble keeping traction before taking the LS1 plunge. Now I'm certain my traction issues will be worse, but oh well :-)
The original engine wasn't anything special (@300 HP small block) and the tires were (and remain) 245/16-50 Firehawks. My (uneducated) guess is that your current rear gear ratio is hurting that bottom-end grunt power.
Old Jan 3, 2011 | 04:18 PM
branj70's Avatar
It seems like it idles to 80 mph with my foot in it! lmao
How do you like the 3.32s?
Old Jan 3, 2011 | 04:48 PM
RedHotG8's Avatar
How can your car idle with your foot into it? lol
Old Jan 3, 2011 | 04:55 PM
1981TA's Avatar
The 3.23s are great. I don't really have to try to light 'em up, and it's good for general street use as well. However, I do have a 12-bolt waiting in the wings with a 4 series Richmond gear set in it. That will be... fun
Old Jan 3, 2011 | 06:17 PM
1998Z28LOADED's Avatar
Me or does it feel like OP is 13 yrs old?
Old Jan 3, 2011 | 06:32 PM
branj70's Avatar
Drive a 3 speed auto car with 2.56s. With my foot to the floor, it'll never rev over 4k all they way to top speed. I was exaggerating. lol
Thanks man . For your information, i'm 19, but i rebuilt my 350 from scratch and only used the machine shop to hone the cylinders and drill for 4 bolt caps. I know my **** in certain areas, others i do not. Transmissions are one of those I'm not good with. No need to be a dick.
Old Jan 3, 2011 | 07:37 PM
Sorry not being a dick, was just confused by some statements and sentence fragements.
