Anyone using this transmission mount?
Old Dec 13, 2010 | 04:17 PM
Fastride500's Avatar
Default Anyone using this transmission mount?
Is anyone using this transmission mount?
Part number 31108G ENERGY SUSPENSION
Need it for my 99 Trans Am, just want to double check that it will fit. Only $27 at autozone compared to $110 for a Gm one, some other guys recommended it to me and said it will fit, what do you guys think?
Thanks for the input.
Old Dec 13, 2010 | 04:26 PM
shortdog's Avatar
9 Second Club/Nitrous Mod
I'm using it with no issues so far. I left the spacer plate out due to vibration and/or you can grind the tabs off to help with vibration also.
Old Dec 13, 2010 | 04:32 PM
Thanks for the tip, I think I will leave the spacer out, last time I had a poly mount it would vibrate so bad at 4-5000 rpm is was horrible.
Old Dec 15, 2010 | 08:52 PM
jwf02ta's Avatar
Do mean to hijack but will it also work on an 02 ta no one in my town has the stock one but they do have that one thanks
Old Dec 16, 2010 | 02:48 AM
slow67's Avatar
Gingervitis Addict
I had one on my T56, and the shifter ALWAYS vibrated a lot. I switched to an oreilly's brand rubber one when I swapped my auto.
Old Dec 17, 2010 | 01:27 AM
sjsingle1's Avatar
seems if you have bad vibes after a poly install.....you have problems unrelated to the poly
Old Dec 17, 2010 | 01:36 AM
masterz28's Avatar
I have it, no problems
Old Dec 17, 2010 | 06:27 AM
tittan1500's Avatar
I have one for sale because it made my car shake likr a jack hammer
