Hurst Pistol Grip shifter installed
Took some work and built a mount, but got it in there...sits a lil high but theres no "right" and it goes through all gear without hitting anything. lil help from Camscam came in handy too ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![](http://i1176.photobucket.com/albums/x327/dbrownss/30276d38.jpg)
Randy, that was the installed height I was going for, but ended up a tad taller, but wasn't enough to make me remake it. Might try and make a shift boot or something to cover it...lol
I made mine out of aluminum plate, but if you'd like I can take pictures and send you the dimensions...any stiff material would be fine. My car was a 6spd so my tunnel would be different to start out with
Randy, that was the installed height I was going for, but ended up a taller, but wasn't enough to make me remake it. Might try and make a shift boot or something to cover it...lol
I made mine out of aluminum plate, but if you'd like I can take pictures and send you the dimensions...and stiff material would be fine. My car was a 6spd so my tunnel would be different to start out with
Yes i like to have some pics of what you did with the base of the shifter.
Mine is a A4 from factory so i know i have to fabricate on top of the factory mounting points. Thanks for your help
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
![](http://i1176.photobucket.com/albums/x327/dbrownss/b649e250.jpg)
Basically I used the base as a starting point. then used 1/2 blocks to raise it to where I wanted then cut the plates and welded it all up. didnt care what it looked like since its under the console, or i woulda worked on it a lil better. Once you get a flat starting point, itll take 20mins to fab up the rest. if you already have mounting points with the auto...prolly be even easier
wow...I didnt even think of that, much simpler and as you said, adjustable. very nice randy. Mine goes from park to 3rd without hitting the dash or console, so im good there. but yours does look cleaner sitting lower. Once I get it all back together I may give myself a lil more credit, I have a switch panel where the gear indicator is, so that might help the look a little more. I do need an ashtray cover though...didnt come with the console.
Ah, didn't even think of yours being a 4 speed, I didn't have elongate mine much, just had to make it wider. Thanks for the compliments, appreciate it, I'd honestly just have to drop it maybe 1/4 of an inch or so and It would be perfect,
