Tuning for new stall suggestions????
Just installed a Phoenix 3400 stall in my '02 A4 firehawk this past weekend, wondering if someone had any good suggestions for proper tuning and adjustments to make???? I have gathered some info here but not too much, any help would be much appreciated.. So far ive gotten:
1. No lock up in 1-3rd gears, lock up at around 48-50 mph below 50%throttle in 4th.
2. No WOT lock up since its a single disk verter.
3. Change the TCC managment lock up settings to Max 100% and min. 90% for quicker locks and less drag time on lockup clutches.
From there im open to any suggestions????
Been searching thru threads all morning and really cant come up with any concrete suggestions, i know ive seen some info somewhere here but cant remember where, hoping for some help, thanks!!!
Best thing I can tell you is I can post a tune for you, then you can compare it to your stock file and make your changes.
It includes, increased pressure for firmer shifts, lock-up speeds adjusted, shift rpms adjusted, torque management deleted.
