What bolts to use for Yank stall w/ stock flexplate?
I put the yank stall in the trans yesterday! I should be able to bolt everything back up today. What bolts should I use? I have the stock flexplate. I know I'm going to have to shim it to. The gap is to much between the stall and flexplate. Also, when I put the stall in, I didn't hear any clicks. More like a clunk sound as it went in.
I need to shim mine. The gap is just to much. I did push and spin. I measured the tc pads to the bellhouse. That came out perfect. But didn't hear a click. I could feel it go in 3 times though.
I used a 3/16 drill bit and talked with Dave at yank. It's all good! I ended up putting masking tape on the washer to hold them in. Worked great. Took the car for a ride and I can tell how much fun this car is going to be. Drove slow and never went over 3000 rpm's. Checked all the fluids. Everything looks good so far. No leaks either. Thanks guys for all the info tips, ect......
