cooler fittings
Question; does anyone know what fittings and line size I will need to fun it? I plan on running braided line from the most convienient point.
Thanks :thumbs:
That is good info but I REALLY don't want to run it from the back of the car. I havn't had a chance to get under the car and look, but I hope I can tie in closer to the front, like maybe the lines connect right under the right side of the motor.
Not trying to be lazy, it's just that it would be SOOO much easier to pick this stuff up on the way home, instead of having to crawl under the car, take everything apart, then run 10 miles back to town
But if I have to, that's the cost of modding
Thanks guys
but if your just trying to rig it off the stock lines....idk about the vette. you probably need barb end fittings and hose clamps.
http://www.purechoicemotorsports.com...rod/prd255.htm
If I use these on the cooler lines (won't be able to take a look until the weekend) and the NPT to 6n recommended in the link above, I might be getting closer
Don't want to do the rubber hose thing.
They are located right at the flywheel (they are disconnected when you pull the trans) If I can get a couple of fittings to screw into the brass female connector and convert to AN6, I can pick up a couple of 5ft braided lines and I'm good to go
