need help topping out at 110
D1sc 236/238 601 605 113
4k stall
Moser 12bolt. 373
Car made 525/442 Car tops at 110 in 3rd , i gota performabuilt 4k an its slippin an got blowby. I want 3rd to top at 150, some people say do 323/342 Gears other people are saying its the converter. What do you guys think it could be? I lost 15mph with blower.
Is it the converter or gears?
4k stall
Moser 12bolt. 373
Big converters slip, even at high rpms. Typically, the bigger the stall speed rating, the more inefficient on the top end. It "may" be spec'd a little incorrectly which could be adding to the problem. Or, there could be something wrong with it, or your trans clutches, which could be slipping also.
The converter is inneficient with the power level it is at. Meaning it's losing mph at the topend because the converter is flashing.
What I said was -blowing through the converter.
I wish the OP would just listen to me instead of making himself look bad. We build alot of high hp cars,so it might be smart to take some advise from us -OP.
OP - now that we know what the real issue is here, you probably want to get a tighter converter and should cure your issues.
8-11% slippage for a 9.5" Lockup Converter like yours mike is completely normal also.....
lets go through it 6000rpm at the crank with a 10% reduction to the output shaft of the trans in 3rd gear gives you a max rpm of 5400..........
5400 rpm / 3.73 rear gear = 1447.72 revolutions per minute of the tire
now a 26" tire has a roll out of 6.80 feet
soooo 6.8 feet * 1447.72 = 9849 Feet/Minute
9849/5280 = 1.865 Miles/Minute
1.86 miles/min x 60 min = 111.9 Miles per hour.............well hot damn look at that 112mph!!!
by no means am i arguing the point that the converter is not efficent or is not a lower quality converter.......im just demonstrating the fact through math that the converter is operating the way it should be for what it is.......
Looks good but it was 112mph at 6600rpm. The converter is made for a purpose but not the power level he is at. The lockup in it could not even hold 380rwhp without slipping.
My car ran 120mph with a Yank 4000 stall at 6300rpm(roughly), same tires/gear.
Either way,too late now. Now I'm wondering if the motor was overspun and ate up some main bearings.
