A4 Blues; What's broke?
After much smack talking I finally broke my A4 in my double oute Camaro SS.
I was driving on one of those 7 degree days last Dec., went to pass someone, (in OD to the floor 4th to 2nd) and car makes a bad brake pad noise in 1st, 4th, and reverse. Trans temp still very cool.
On jacks, in reverse, trans would lock up, wheels would not spin backward. Now it doesn't do that anymore, but still makes bad brake pad like noise. I don't think I smoked any clutches, but think I broke the spag or something came or broke loose. All gears still work. Just need to know what is broke before I open trans up when it gets warmer.
On jacks, in reverse, trans would lock up, wheels would not spin backward. Now it doesn't do that anymore, but still makes bad brake pad like noise. I don't think I smoked any clutches, but think I broke the spag or something came or broke loose. All gears still work. Just need to know what is broke before I open trans up when it gets warmer. Enter a couple symptoms in the search, Ive tried the same thing, when thinking about upgrading mine to prevent this, and I know Ive seen something like that in there, youre definately on the right track. Good luck
On jacks, in reverse, trans would lock up, wheels would not spin backward. Now it doesn't do that anymore, but still makes bad brake pad like noise. I don't think I smoked any clutches, but think I broke the spag or something came or broke loose. All gears still work. Just need to know what is broke before I open trans up when it gets warmer. we do rebuild the transmiisions for performance needs. We put a 5 pinion plaitary put blue clutchs better sunshell and kevlar bands along with many other things give me a call at 203-619-4732 if you need a transmiision refresioned
thanks guy
thanks guy
