98 Z28 Tranmission Clink when shifting from R to P
All
My wife has a 1998 Z28 with an automatic transmission. The car has 89k miles on it. When she comes home she backs down the drive way and angles towards the garage. She then has to shift from R to D to pull forward to straighten up and then from D to R to back up and then from R to P to Park.
At each shift (R to D, D to R, R to P) I hear a slight "clink" noise (definitely not a "CLUNK")
It is driving me crazy. Is it the U-joints - and are they servicable?
Thanks
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Thanks
I truly hate this car - it's my wife's and I drive a Dodge truck which you don't have to put on stands to see under the damn thing. ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
So I am trying to find this torque arm and just not seeing it. Is it a round tubular arm or is it a c-channel type arm.
Any diagrams available on the WWW that will show me this thing?
See the black thing under the drive shaft? Its got 2 bolts going straight down. Thats the torque arm on the rear end side. Now follow that black thing all the way to the trans and you will see the next pic...
![](http://i489.photobucket.com/albums/rr253/senicalj/Norwich-20110314-00102.jpg)
Here is he trans side of the torque arm. See the bolts going through it? Theres a rubber clamshell in there. Its called the torque arm bushing.
![](http://i489.photobucket.com/albums/rr253/senicalj/IMG-20110314-00105.jpg)
Here is the torque arm detatched from the trans.
![](http://i489.photobucket.com/albums/rr253/senicalj/IMG-20110315-00107.jpg)
Heres a pic of how long the torque arm is under the car. This is without my drive shaft or exhaust in place.
![](http://i489.photobucket.com/albums/rr253/senicalj/IMG-20110315-00109.jpg)
I think That should just about do it for you
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
How hard is it to remove the mount on this where the bushing goes?
