Rmvb th400
Old May 8, 2012 | 02:13 AM
LS1-Tuner88's Avatar
Default Rmvb th400
I have done alot of research on the driving habits of a rmvb. My question is i have read that retaining the intermediate band in a rmvb th400 makes it more street friendly. Is this true or no? If your wondering what tranny im looking at its a Rossler Terminator 1 th400.
Old May 8, 2012 | 10:59 AM
70 views and no one has has an answer? Come on now
Old May 8, 2012 | 12:34 PM
slow67's Avatar
Gingervitis Addict
Yes it is true. Otherwise, if you were in second, let off the gas, then whacked the throttle, there is a chance you could roll the intermediate sprag.
Old May 8, 2012 | 12:35 PM
72blownvert's Avatar
The band is there for engine braking, with that being said i have never used a rmvb that had engine braking i have heard good and bad about it.I build alot of units with rmvd's for street cars and never had any problems as long as you know how to drive with it on the street.If the car is more like a daily driver you might want to go with a unit that takes a band if the car is more of a track car then you really don't need a band in the unit.
Old May 9, 2012 | 02:26 AM
It is mainly going to be a street car
Old May 9, 2012 | 02:29 AM
gregrob's Avatar
A good rule of thumb is dont put it in 2nd, or 1st if you're going to fast for it to "normally" be there. You can throw it in 2nd at 130mph and it will just free wheel, but the internals go 2.5 times drive shaft speed and can explode!
Just use common sense..
Also use the brake to back up... If you put a lot of strain on reverse, it is also the direct high gear clutch pack and can wipe it out.
Old May 10, 2012 | 11:59 PM
I understand not to down shift after getn on it hard. Im more concerned with normal driving. for instance, if im needing to slow down for a turn is it cool to hit second or it need to stay in third?
Old May 11, 2012 | 02:52 PM
SuperSlow02's Avatar
Just leave it in 3rd till you come to a stop. Usually how I roll on the street.
Old May 12, 2012 | 03:59 PM
is there any difference between a rmvb and rmvb with a brake?
Old May 12, 2012 | 09:58 PM
Shouldn't be. Depends on the VB though...I've heard some of the VB with a brake will require you to use the brake to engage reverse
Old May 13, 2012 | 03:09 AM
Wow. there is a 6-8 week waiting period for rossler to build me a tranny.FML
