4k stall in turbo car with th350 to high?
as the title states car is turbo with it seeing street and strip use is the 4k stall too high for it being turbo and being out on the street? car has 3.42 gears as its swapped from a 6 speed
Moderator
This was recently discussed:
https://ls1tech.com/forums/automatic...tall-much.html
I think the consensus is that it is a bit much for 100% street use, but would be fine at the track with the fairly aggressive cam you have.
Me personally, I would say yes. I'm no expert, but with that big of a turbo on a 4k stall, traction will be damn near impossible. You'll be pretty much all in by then, and with the torque multiplication, you'll blow the tires off! I would think a high 2000s or low 3000s stall would be better suited for you.
