What should I do to my 4L80E?
Looking for suggestions as to what do do with it
Case: Use a Sonnax no walk out case bushing and install it from the tailhousing side of the case. This will give the output shaft more support and also center the th350 bearing in the case. Always check output shaft and intermediate shaft clearances. Then check band lugs in the case makeing sure they are not loose or punched in.
Intermediate clutch: Keep the wavey that is already there and use a Torqueflite 8 forward drum snap ring .106". I machine my case and use a spiral lock ring but .106" snap ring is a good upgrade from stock.
Direct drum: Check sprag race and sealing ring area for wear. Drill a .055" hole on the inner corner of the edge where the outer lip seal rides. Use six high energy frictions using the .077" steels and set your clearance to .060"-.075". Replace the old sprag with a new one.
Forward drum: I do alot machine work on this drum for support but, you can start with cheking for ring and bushing wear. Add five high energy frictions and set your clearance.
Overdrive planet: It is rebuildable so, you can tear it down and change the washers to reset clearances.
These are just a few tips to help you out on your build. More performance oriented modifications like dual feeding, strategic bearing placement, and billet parts can also be used.
Overdrive roller clutch: There are two types the .310" O.D (witch is the stronger of the two) and the .195" O.D (the weaker one). The later models have the weaker version. You can get a complete overdrive drum and an overdrive planet from an early unit to upgrade to the stronger roller. I use a sprag from a european type transmission and machine the race and case harden it for my upgrade but, that is a bit too much work for the DIY.
The pump: Always use a new boost valve. I prefer the sonnax or superior type because of quality. I,ve seen the transgo valve go out in as little as 20k miles. You also want to make sure the end plugs in the valves are not leaking. Use a Ford C6 pump bushing on the late pump for better support and an added oiling groove.
Remember the key for it to live a long life is to keep everything running on center so, check all your bushings for wear and replace if worn.
What about stalls? I love Coan and Art Carr but its been a while since ive run an auto and theres lots of newbs in the game now
Another one, what is a rule of thumb for bushing to shaft clearance?
Thanks,
Stevebbc
saves you from big problems
