Installed tranny, now engine won't turn over?
Trying to turn the transmission pump shaft (the larger / outer shaft w/ ears on it) by hand, I can't. I don't know why not, and this seems to be the problem.
Parts & more info
I have an 02 4.8 Vortec engine from a Silverado and what I am told is an LS1 Camaro 4L60E transmission.
I am using the dished Vortec flex plate.
When I bolt the whole mess up it the engine can't be turned over.
When I bolt the torque converted to the flex plate (transmission off to the side) it seems to work fine. The engine turns over freely and I see no interference issues.
So, WTF? Did I buy a seized up trans, or is there something more to it that I don't yet understand?
My first Chevy project... I really know nothing about this stuff.
Otherwise, you might have installed the converter incorrectly and cracked and jammed the pump in the trans. The pump is the only thing that turns in the trans before the pump builds pressure.
These threads might help you (especially the first one):
https://ls1tech.com/forums/automatic...ter-bolts.html
https://ls1tech.com/forums/automatic...questions.html
https://ls1tech.com/forums/automatic...lp-please.html
Keep us posted when you figure it out. And good luck.
It sounds as if you maybe don't have the converter seated all the way into the transmission.
There should be 2 distinct clunks as you rotate the converter while installing it on the trans. At each clunk, the converter moves farther onto the shaft.
Ron
Incidentally, the ARP flex plate to TC bolts are harder to work with than the factory stuff due to length issues. Oh well, got it worked out.
Thanks guys!
What will break is the front pump gear. That is what is the final engagement you felt as the tags on the converter mated with the pump gear. Since you didn't turn it over, could be ok.
I guess you will know when you go to drive the car.
Ron
DDD
For my own education, is the damage usually limited to the pump or does ground metal get distributed throughout the trans?
(Perhaps this depends upon whether the engine was started?)
The flexplate is bent.When you butted the TCon hub against the pump rotor, something has to 'give'....and that will be the flaxplate since it is only 1/8 inch thick.They are cheap, so replacing it should be automatic.The TCon MAY be OK.Any marking on the hub and you should just replace the TCon.Atempting to run the trans with ANY of those parts damaged will cause severe damage the the trans and it will need to be completely redone.If their is any doubt about the condition of any of those parts, have a pro trans tech look them over.
DDD
I'm really, really hoping I didn't do any expensive damage. Financially I'm in way over my head as it is.
Good luck with everthing.
