question about deep pans
Old Feb 4, 2013 | 06:58 PM
mjs1012's Avatar
Default question about deep pans
anyone here run a deep pan on their 60e? im just curious how much cooler the transmission would be if i ran one. if anyone has a pic of how far theirs hangs down can you post it along with what brand.
also, is it true if I were to use the pan from the full size trucks with the drain plug that it holds about an extra 1/2 qt or so?
Old Feb 4, 2013 | 08:37 PM
Jake's Performance's Avatar
A deep pan helps fluid temp because it takes longer to heat a greater volume of fluid. It also has more surface area exposed to cool air to radiate heat.
The truck pan probably holds a qt more. It's cheap too, about $20 new from GM.
Old Feb 4, 2013 | 08:58 PM
BOLO's Avatar
Wow $20 for a new GM 4L60E trans pan? Good to know. Thanks Jake.
Old Feb 4, 2013 | 09:07 PM
mjs1012's Avatar
yea thats cheap and it has a drain plug
Old Feb 4, 2013 | 09:32 PM
Yeah,
The shallow 700-R4 style pan is available new for a bit over $20 and I think I paid $17 or so for the deep truck 4L60E pan recently.
Old Mar 18, 2013 | 09:04 PM
farmington's Avatar
anybody have a part number for this truck pan or at least what year and type of truck it comes on? I take it that this uses a different (deeper) filter too?
Old Mar 18, 2013 | 09:29 PM
Stardust's Avatar
I have been thinking about getting this one?
http://www.summitracing.com/parts/der-14204
"Derale Cooling Products transmission pans can double your transmission's life by dropping its temperature 20 to 50 degrees. These pans hold additional fluid and have heat-conducting metal tubes on the bottom. A replacement gasket is included"
Old Mar 18, 2013 | 10:05 PM
mrvedit's Avatar
Moderator
We just had an entire thread on that:
https://ls1tech.com/forums/automatic...ooler-pan.html
I wouldn't use it if you paid me because it hangs down too low. I doubt it cools much; it won't cool at all in stop-go traffic which can heat up the trans especially with a high stall converter.
Old Mar 18, 2013 | 10:21 PM
mrvedit's Avatar
Moderator
I am very happy with an deep (truck sized) aluminum pan I found on ebay. Search for "GM 700R4 Polished Aluminum Transmission Pan Deep 4L60E"; the seller is
abad71camaro. This holds one extra quart, same as the truck pan. (Most aluminum pans on ebay are standard depth, this is the only deep one I found.)
They also have it at their website:
"http://www.asaperformance.net/servlet/the-10065/GM-700R4-Polished-Aluminum/Detail"
Old Mar 18, 2013 | 10:27 PM
Stardust's Avatar
I didn't catch that one. I'll be putting in a B&M cooler soon.
