Torque Converter install ruined pump?
Old Dec 24, 2013 | 01:04 PM
rwerk91's Avatar
Default Torque Converter install ruined pump?
So first auto car Ive built and was unaware to place TC onto tranny then bolt to flywheel/motor. Bolted it onto motor/flywheel first. Clocked ears on TC by eye to notches on tranny and slid tranny on and bolted up. Car starts and and shifter goes into gear but car doesn't move and no pump pressure. So question is what are the chances of simply removing TC and reinstalling correctly and being good or will I for sure most likely have to replace the pump? Also there were two connectors on the harness similar to O2 connectors that ran back to the tail of the tranny pretty sure that don't go to anything or am I wrong. Don't remember disconnecting them or seeing a sensor to plug them into. Thanks, Oh forgot the cars a 98 Z28 (auto obviously)
Old Dec 24, 2013 | 01:09 PM
omar2guy's Avatar
Will most likely have to replace the pump, usually this happens if the converter isn't in all the way and then bolted up, and I think atleast one of the plugs is for the speed sensor
Old Dec 24, 2013 | 04:51 PM
jimmyblue's Avatar
Moderator
If it was not engaged -at all- then maybe no harm
has come of it. Partly engaged, you might strip the
pump shaft I guess. May as well give it a try and see
if you can seat it right. Can you inspect the pump
input shaft for signs of fresh damage?
Old Dec 24, 2013 | 05:11 PM
anheuserbusch08's Avatar
U broke the transmission oil pump it has to be installed in the transmission first then bolt it up to the engine and flywheel.
Old Dec 24, 2013 | 05:54 PM
rwerk91's Avatar
Thanks for the feed back guys. Crossing my fingers pumps ok. Expecting it won't be though. Cars at the shop the shop right now. Tired of working on it so gonna have them pull it and check it out. I completely pulled I meme we and all and rebuilt motor the last couple weeks. Burnt out.
Old Dec 24, 2013 | 05:55 PM
rwerk91's Avatar
I meme we (*k member)
Old Dec 24, 2013 | 08:44 PM
PontiacFan's Avatar
Huh?!?
Sounds like you have a lot of reading to do, ..., in order to learn how to do it right next time.
Look up top here, ..., 'Stickies', ..., read all you can as there's a lot of good info there on what to do & how to do it.
Old Dec 26, 2013 | 05:05 PM
SSZ's Avatar
SSZ
Man that sucks. Pump is likely effed up. Hopefully the guys at the shop know how to inspect properly. I feel for ya. SOmetimes ya gotta learn the hard way.
Old Dec 26, 2013 | 08:24 PM
allout06's Avatar
https://ls1tech.com/forums/automatic...education.html
Old Dec 26, 2013 | 08:25 PM
allout06's Avatar
dont forget to check your spacing
Old Dec 26, 2013 | 09:50 PM
1BAD98LS1's Avatar
I've seen this happen before on a buddy's car except he simply didn't push the convertor on the input shaft all the way...same result, ended up breaking the trans pump. sucks and a shitty lesson to learn esp. when your doing it all on your back without a lift lol
