Transmission Rebuild ?
If there is any metal debris or even significant friction debris in the trans, the converter also needs to be replace or at least sent away for opening and cleaning; the cooling lines also need to be flushed; any aftermarket cooler needs to be replaced.
People that try to "cheap out" on replacing the converter and cooler often later complain that their new trans also failed. Just flushing the converter is never enough.
I agree on the last part. I lost my 3-4 clutch pack, I'm buying a new cooler, upgraded lines and had my converter cut, cleaned and restalled.
