trans brake not working
Old Feb 23, 2014 | 08:52 PM
SF 1HOTLS1's Avatar
Default trans brake not working
So my trans brake isnt working. I can hear and feel the selonoid click but it wont actually work. Yes i have it in first gear.
Any ideas?
Old Feb 23, 2014 | 11:28 PM
Jake's Performance's Avatar
Any ideas?
What trans?
Old Feb 24, 2014 | 04:43 PM
SF 1HOTLS1's Avatar
Th400
Old Feb 24, 2014 | 04:44 PM
SF 1HOTLS1's Avatar
Even worse, my trans was whining with any acceleration and is now not working. Sucks to be me.
Old Feb 24, 2014 | 05:51 PM
Whining is indicative of low fluid level or a plugged filter.
Check the fluid level and condition. If it's OK you may need to drop the pan and look for debris, filter condition, and check the pickup tube for cracks, be sure it has (preferably) 2 orings in the case end.
If you ran it low on fluid, it likely needs a rebuild.
Old Feb 25, 2014 | 04:00 PM
SF 1HOTLS1's Avatar
Thanks for the reply jake, the shop filled it and i confirmed it also. Was full.
Hopefully when i drop the pan all looks well.
Any idea in why the brake isnt working?
Old Feb 25, 2014 | 07:08 PM
I would put a pressure gauge on it and see what you have. If it doesn't have proper pressure, it's not going to work.
Old Feb 26, 2014 | 10:27 PM
SF 1HOTLS1's Avatar
we tested it right after we installed it. had 200-210. around there.
right after the t brake was wired is when the whinning noise came. im assuming it may of had low pressure when whinning and is why it didnt work.
FTI, the manufacture, said to pull the selonoid out and remove the o ring seal on the selonoid and then try it out. I forgot why they said to do this, but i will try this after i fix the trans.
