Done with the 4l80 Swap!
4l60e car formerly. Now has jakes stage 5 D3 transbrake late model 80e. (97+)
When you put the car into OD or 3rd or 2nd...that is the gear the car is in and moves in. If you shift it manually it will go into gear and drive almost like its a FMVB. This is supposed to be electronically controlled. When you hit the transbrake button to put it into reverse it will lunge backwards and stop just as suddenly.
I am not using a segment swap. I am using a wiring harness adapter from frost tuning.... http://www.tunedbyfrost.com/products_dev1.htm
My question is simply, has anyone ever had this issue, and are there any codes that could be causing this to happen. Not sure if it makes a difference, but I have deleted, traction control, ABS and cruise and everything from the car.
Thanks in advance.
Burken 01, you should join the boosted lsx page. i was looking for you on there the other day.
RPP used their Snap On scan tool to scan for codes and it showed nothing. I found the info frost had up on the EFI forums and had a discussion at length with my tuner who may be able to ride over to RPP tomorrow and see what he can find out. Slow67 said it was possible to tune the car to act like FMVB. The tuner said it was also a possibility that a harness/wire was loose inside that he had seen this before and it was a simple pan pull away from working. There are a ton of possibilities. It'd be nice to have Jake and them in touch with one another to come together and troubleshoot so it can be on the dyno sunday.
That is why I sent Jake a PM just now trying to get him and the tuner on the phone together while the car is hooked up to a computer and work together on the phone to resolve the issue so I can put some power through that badboy. I think between the two they would have it narrowed down if not solved in a few hours.
and here is something shortuning posted earlier.
The transmission is manually going into the forward gears fine manually. Reverse is not functioning correctly. I had limited time with the car over the weekend but the changes recommended were uploaded and nothing changed. I'm thinking it's a good idea to ditch the harness crap and just 80e segment swap the PCM like I always have done in the past. I have access to all the TCC tables to prevent the unlocking at closed throttle and the shifting issues that used to be associated with an 80e file. None of those issues are an issue anymore.
It sounds to me as if something is mis-wired, activating the transbrake/reverse when it shouldn't be, or not activating it properly, like it's setting off a circuit breaker shortly after engagement.
If 3rd gear works, and you have engine braking in manual 1st gear on decel, everything internally is working for reverse
If it locks up when engaging the reverse, it would point to a burnt forward clutch which we've seen when one has been low on fluid or not enough pressure in the tune causes low fluid pressure. Once it's welded together, you will not have reverse.
You may try tuning it to maximum pressure to eliminate variables until you get it sorted out.
Also,
If memory serves, this is a unit we shipped some time ago. I would confirm the pinout of the D3 brake wiring, we have made some changes to that since we introduced it.
Also, what environment was the trans in while awaiting install?
