4l60 e I'm stumped and really need help
Old Mar 17, 2014 | 03:11 AM
Lsierra32703's Avatar
Default 4l60 e I'm stumped and really need help
I have a 03 sierra with a bad trans should I take my chances at a junkyard and pull one to put in or should I just order a rebuild kit and do it my self, I've never had to rebuild a gm transmission Idk if it's hard or not I have all the tools to do it and I'd love to learn how to rebuild them and I don't have the money to take it to a shop "common problem when you blow all your money on the motor" should I pull the trans I have and rebuild or buy a used one from the junkyard and take my chances
Old Mar 17, 2014 | 08:13 AM
LS1MCSS's Avatar
Get a used one.
Old Mar 18, 2014 | 03:17 PM
Why not rebuild with a stage 1 kit
Old Mar 18, 2014 | 05:58 PM
novaflash2002's Avatar
unfortunately rebuilding a transmission is not nearly as simple as rebuilding an engine..... Ive seen many talented mechanics attempt and fail at the task on even a simple th-350/th-375b.
If its just a std sierra... the junkyard unit will suffice (most of the time they even come with some sort of warranty). If not you can make the specialty tools you need for the 4l60 easily... or spend the $2000ish on a stock rebuild.
Old Mar 18, 2014 | 06:47 PM
But I've seen kids that are maybe 15 years old rebuild a 4l60 like it was nothing
Old Mar 18, 2014 | 11:30 PM
RevGTO's Avatar
Pontiacerator
Then get one of them to guide you and go for it, dude!
Old Mar 19, 2014 | 07:39 AM
SSGunn's Avatar
I'd get a used one... if you try to rebuild one and end up ******* it up then you worse off then you started... dont take chances if your not positive you know what your doing. Transmissions arent easy to rebuild.
Old Mar 19, 2014 | 08:05 AM
Tolley's94z28's Avatar
Why don't you pick up a used tranny from a junkyard and throw it in. Then tear the old one apart and learn how it all works!
Old Mar 19, 2014 | 09:08 AM
WE TODD DID's Avatar
x2. They're so easy, a high school kid can do it.
Old Mar 19, 2014 | 11:34 PM
see that's what I thought todd I was told they were super easy to rebuild ive only ever done Honda transmissions but never a gm but was told if I could rebuild a Honda 6speed that id have no problem redoing a 4l60e
Old Mar 21, 2014 | 04:27 PM
Well I found out that the shift solenoids are what's making it **** up so ima change them a see how it goes
