Help! Transmission overheated, blown.
I had asked the people in tire kingdom to make sure the coolant system was 100% because i didn't want any problems with overheating the engine or transmission.
After they did all this work for $1000, they never replaced the cap. What I saw was the reservoir was always full, and not moving. I didn't realize that the water in the radiator was going down.
Does the transmission fluid line go into the TOP of the radiator?? Why was the transmission overheating before the engine would?
Since I've replaced the transmission and the radiator cap, im fine. but pissed. I dont have the money for this and had to put it on credit. Since I've replaced the cap, the water in the reservoir fluctuates properly.
Also, tire kingdom is claiming there is no way to inspect a radiator cap other than visual. Is this true?
I'm out 1100 for a transmission because it kept overheating. Im sorry but they should cover this loss. Pissed. I had no idea what was happening because the reservoir was full.
It's really hard to find an honest mechanic who does good work. It seems like they'll either be cheap but do bad work, or do good work but charge waaaaay more labor than you know it took them. I recently had a shop charge me $150 labor for a 20-30 minute job, but said it took 1.5 hours. I asked the specific mechanic at the shop who did it if he had a lot of problems or something but he said it was really easy and went smoothly.
I am probably not going to be able to prove it was a bad cap that caused overheating issues, then causing my transm to overheat and blow
Is the transmission fluid temperature not affected by the airflow through the radiator? I would think there would be some cooling by airflow, and since the coolant isn't circulating through the engine the coolant wouldn't be heating up the transmission fluid like it would during normal operation since the coolant thermostat typically holds it to about 190F. It seems like if the coolant wasn't circulating, the radiator would basically be acting as an external transmission cooler.
And if the transmission overheated before the engine, that seems odd. The transmission doesn't generate a lot of heat unless you're shifting constantly, like in congested traffic. If the coolant wasn't circulating, the engine should exceed normal operating temperature very quickly.
When there is no coolant in the radiator, there will be very little cooling of the trans fluid.
I don't have the experience to even guess at how much cooling the trans needs in a stock V6 engine, but perhaps it does need what the stock cooler provides.
Cory, I agree that I would expect the engine to overheat first.
OP: Keep an eye on the trans fluid. I assume you know it needs to be checked with the engine running. If the fluid level goes down, but you see no ATF leaks, it could be leaking into the engine coolant within a defective radiator. This will kill the trans very quickly .
