Where to get Transgo, Vette servo, accumulator, etc.
I got the Trans Go through my trans builder along with the Billet servo and kevlar band
I got the Beast sunshell off Ebay and my builder had me get one for him too.
All the stuff is on Ebay to compare prices and part numbers. Just search 4L60E in the parts/accessories - transmission section.
Go to http://www.pro-built.net/index.cfm?f...t&productid=91 this will give you the "modified" Trans-Go Performance Shift kit. You should already have the Corvette servo. As for the billet servos..... pass, not necessary when using this kit. This kit will give you smooth part throttle shifts, and firm WOT shifts, and that is what is needed to keep these units living. Let me know if I can be of help?
Guest
Posts: n/a
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Originally Posted by Naked AV
How is the kit 'modified'? And what do you mean by 'You should already have the Corvette servo'? Did you already send me one? ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
That is why I went with the Billet servo.
Guest
Posts: n/a
Well actually, I have a GMPP new in the crate that I was going to install a shift kit, Vette servo, and converter into before putting into my truck. Are you saying that the GMPP 4L65E already has the Vette servo? That would be interesting, because many of the guys over at SilveradoSS.com have had their trannies upgraded and had the Vette servo installed (if that isn't a performance application, I don't know what is).
Are you absolutely positive that my GMPP 4L65E has the Vette servo in it?
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Anyway - my builer was good with the advantages of the Billet servo for the price over the Vette one. I only wanted to build the trans once so he used what he thought would prepare me for future upgrades and still be fine as it is now.
It was not overkill and my shifts are awesome in every gear.
Sorry I don't have a part number on hand for you since the builder did the check for me. If I find more info I'll post up here.
