View Poll Results: is 3500 stal on a 4l80 a good DD? (about 700hp+ fbody)
sure!
13
81.25%
not the best but it can be done!
2
12.50%
It's a TRAP!! (NO)
1
6.25%
Voters: 16. You may not vote on this poll
3500 stall as DD?
Old Jan 10, 2018 | 08:46 PM
SesiomSummers's Avatar
Default 3500 stall as DD?
hello guys I have a question, does anyone here have any experience DD a 3500 stall with a 4L80 in a Fbody?
Im still not sure what high stall does on cars so any link or a good explanation about would be awesome!
Old Jan 10, 2018 | 10:34 PM
LLLosingit's Avatar
We put a Yank 3600 stall in my Son-inlaws Nova 6.0 4l80, It still runs the stock cam for now but it takes off pretty easy, Most people would think it was a stock stall until you step on it hard...then it shreds the tires lol
Old Jan 10, 2018 | 10:38 PM
clinebarger's Avatar
I have a 245mm Circle D Pro billet 3200-3400 converter in my car which is perfect for my mild cam L92 that makes a boatload of torque at 3200.
It really depends on your combination!
Old Jan 11, 2018 | 07:44 PM
Jtm2085's Avatar
As long as you buy a quality converter you will be fine. I got a custom converter from FTI that stalls at 4200 and I don't see why it would be a hindrance to drive it daily.
Old Jan 12, 2018 | 08:12 AM
... Its from Mad Dog...
Old Jan 12, 2018 | 08:19 AM
85LSXTRUCK's Avatar
Drive my 3500 circle d all the time with zero problems. Only difference I see is when I hit it hard from a stop it rips the tires .
Old Jan 12, 2018 | 08:34 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
to OP,you didn't mention what is your rear end gear ratio,has a large effect on how an aftermarket higher stall feels as a DD.
Old Jan 12, 2018 | 09:10 AM
01ssreda4's Avatar
what a fucktard that guy is.
Anyway this may help you see how a converter effects your driving.
https://ls1tech.com/forums/multimedi...uge-shots.html
Old Jan 14, 2018 | 10:24 AM
01Z0H6's Avatar
Back in the day I used the Yank SY3500... It was a sweet converter... They stopped making it long ago. Since then I have always had great luck with the SS series 3600-4K..
