4l60e wiring harness, help needed (PNP switch)
I'm swapping 5.3 LM7 along with Holden LS1 wiring harness (similar to '04 GTO harness, has the same DBC factory setup), converting to emission-free setup (thanks to lt1swap.com).
Will buy a transmission later (I need to find 2WD 4l60e and they're pretty rare in my region).
Harness has a BLUE and RED connectors for PCM, and nothing went wrong with it untill I've got some unused wires comes from neutral safety switch.
I've got this type of connector:
Now I have connected to my PCM only these wires:
#4 - Transmission Range Switch Signal B
#5 - Transmission Range Switch Signal A
#6 - Transmission Range Switch Signal C
#8 - Transmission Range Switch Signal P
Here's a photo of my connector (from it's back side), wires on top are connected to PCM and wires on the bottom are leftover.
What should I do with these?
This wire is connected to my range switch connector right now (it's a white one - #8 Transmission Range Switch Signal P).
Also it says that PCM can be reprogrammed to accept a single wire (park/neutral signal) on this #34 pin if there's no trans mounted range sensor is present.
I'm confused because I've tested those connected wires and they come into my PCM:
And looking at the wiring harness itself - those wires from the range connector do not come through my round trans connector - they're going separately to the PCM as you can see here:
So should I:
1) Left my range connector "as is" and just tape off those unused wires?
2) Connect those unused wires according the scheme I've posted earlier (ground and both power supply wires)?
3) Cut off the entire connector and just route #34 white wire to my shifter and later program PCM to "P/N only" mode (1-wire)?
This is the first time I'm dealing with AUTOMATIC transmission
About 2 days I've spent trying to figure out WHAT transmission I can use with LS engine (I was thinking about TH400 or something like that because they're much cheaper and no electronics needed) and after all I've decided to go with 4l60e because "plug and play". But this wiring situation just stopped the whole process
You should at the least wire it up so the pcm has a park and neutral signal. It would be wise to have a neutral safety also. Reverse lights would probably be nice. That's what that switch does. It has nothing to do with the pressure switch manifold (psm) inside the transmission.
But I don't know what to do with the rest, which are not connected - that's the deal.
It's a swap vehicle, yes.
https://ls1tech.com/forums/automatic...ification.html
Pin 1 - PNP/Clutch start switch signal
Pin 7 - Ground
Pin 9 - Park Neutral position switch signal
Pin 11 - Ingition 1 voltage
Pin 12 - Ingition 1 voltage
Maybe I don't need pin #9 as long as I will program my PCM to "P/N only" mode which needs only #8 pin that goes to #34 pin of the blue PCM connector (mine is connected).
Ground and both wires to ignition - okay.
But maybe someone can tell me how exactly shoul I connect them?
http://www.lt1swap.com/
BTW my wiring harness came without starter solenoid wire and I thought maybe it had a wire that came from my RANGE connector to the starter?
But as long as I've cut off some wires from my PCM connectors (#5 "Delivered Torque Signal" and #12 "Ignition Retard Signal" came off according lt1swap.com chart) - maybe those wires that I have left now at the RANGE connector came in those PCM pins?
(Something like when my car is NOT in P/N it won't start).
According to chart from my first post there's power supply (what for? I mean why range connector even needs +12?) and ground along with reverse lights.
Get a DVOM and verify ground continuity 9.
Or do whatever it takes to send a park and neutral signal to the PCM. In other words send a ground to the pcm in park and neutral however you can. This only effects idle timing and a few other things.
If you can't figure it out, take the switch and it's wires off and throw them away.
It will run just fine without it.
The switch provides power to reverse lights while in reverse.
It lets the pcm know when it's in park and neutral.
It provides a neutral safety so it won't engage the starter in gear.
It does not connect to the starter. The starter start wire goes to the start relay. The range switch makes or breaks the relay coil power.
If you can't figure it out just bypass the neutral safety switch wire in the swap vehicle so it will start, and toss the switch and it's wiring in the trash or to do later box.
Sure would be helpful to know all the info. Say like what vehicle it's in. I have a swap vehicle and the neutral safety, park neutral, reverse lights are all handled through the shifter mounted switch. Thats why I tossed the transmission mounted range switch in the garbage.
And what kind of shifter are you using? (it's aftermarket I guess)
Did you cut off those wires as well?
I'm thinking of buying some kind of a passenger van (Russian crap actually but pretty cheap and all of them were only manual transmission so I'll have to mess with any kind of AT shifter anyway) and swap it in there...
But also I have a sitting about a year Volvo 740 wagon than needs some floor repair (but runs great).
I have to buy a transmission anyway and can't afford T56 (they're about $2000+ for used ones in my area) so messing with 4l60/80e.
Thanks again for the input!
I wired it up to provide a ground to the pcm in park and neutral. And to have a neutral safety. It has two switches for these.
I made my own wiring harness so the range switch (pnp switch) wires were never there.
It works fine. It reads when it's in park and neutral as verified on hptuners scanner.
It also reads what gear it's in via the pressure switch manifold inside the transmission. The two switches operate independently.
I'll go the same way you did it.
