What 4l60 easy upgrades
seperator plate trans go part number 46-PLT-96 wasn’t sure if this was the right one says it should work for 98 car but figured I would ask the experts.
what shift kit is recommended for the 4l60 trans go hd2?
also have a sonnax boost valve and HD 2-3shift valve planne.
Just looking to to do a few mods that can be done with the trans in the car not looking to rebuild it at some point I will get it built but doesn’t look like funds will be there for this winter point me in the right direction.
That car should have a corvette servo already.
Maybe get aluminum forward and 1-2 accumulator pistons. Maybe D ring seals for the servo and accumulator pistons.
Haven’t tried this before so I am trying to lean on guys that have exsperiance.
I also drilled the plate to his specs. So give him a call because his hole sizes were quite a bit different from the transgo instructions since I'm running a 4000 stall converter.
I drilled the hole for the hd 2-3 valve and race in D3. Currently spray 150 and will spray 175 next weekend for mid 10s. Car shifts great:
Get torlon check ***** as they won't wear into the plate over time. I bought them but didn't get them in time so they are on the shelf :/.
and i prefer the sonnax kit over the TG kit.....jus sayin.....
Hardtop Brian I have followed your build some should have a similar set up to you for next season so definitely want to see what kind of durability you get out of those mods.
checkballs sonnax part number10000-08
forward piston sonnax part number 74927-AP or 77987-01K
1-2 accumulator piston trans go part number 4L6-2ACM
anything else people recomend other other than the parts I have listed?
