4l60e failure??!!
i know this has been ran down 5,000,000 times on here. But I'm just got towed 8 hrs home finally and with weather (west tennessee pms) have had no time or way to remove yet. So I just want to see if my theory may be correct.
Started up Saturday morning before Christmas and had a small noise that sounded like an exhaust leak. Figured ah WTH it's prolly an exhaust leak and cruised on into town. After about 25 mins of driving it was still there. No louder or quiter. So pulled in at AutoZone and shimmied under it and it sounded as it was coming from TC. I told myself this was it and I wasn't making it back from Knoxville. So I went ahead and bought me some shocks since mine were blowed continued to families house and replaced them. Later that night we went out to eat, exhaust leak still there and still pretty quiet. We left and headed back to families and as we turned into the neighborhood got to maybe 35-40 and vroooom!!! And the exhaust leak then sounded like a wrench moderatlmo tapping the bell housing!!! No gears.. looked at my fiance and said there it went. There went a freshly rebuilt trans 872 miles beyond warranty and 369 miles from home!!!
Anyhow got it towed back to families in the neighborhood and started trouble shooting!!! Check stupid stuff like it could really be it. Check fuses, made sure it had fluid, no leaks, restarted and still no pull anywhere. When you engage a gear you can hear it bog like it's about to make your a** hole out of your gut but nothing. So finally pulled the stick running and not running andafluid looks like it just came out of the quart.
1.
So I marked the dipstick not running and fired her up and she drug down nearly 3/4-1". So im sure the pump is pumping.
2.
There is no discoloration, burnt smell, or debris in the fluid at the stick.
3.
I still have park and it free rolls like it normally would neutral.
So I'm to the point of just trying things when it dries before I just buy a new trans!! I know allot of what it could be. TC, pump, input shaft, output shaft, ect
But pump is working which tells me it's good and part of the TC is operating like it should. With that wouldn't the input shaft be good? And with park operational wouldn't the output shaft be ok?
I'm just curious in TC failure could cause this? Or maybe solenoid? Or what????
Pump pulls fluid down as it normally would in all gears. Sounds like it's about to engage and take off. I don't race and motor is stock! Any ideas or maybe someone has hopefully had this string of luck cause if I can manage to fix this newly rebuilt trans with a TC or solenoid ect I'd be ecstatic!!!!!
Thanks!!!
As soon as I find out I'll post. I'm really thinking input shaft but praying it's a simple TC swap and be done
letting go all of a sudden doesnt sound like clutches. wouldnt be a solonoid, you will manually have reverse and first. probably the input drum cracked and then the splines stripped in the drum. Did it originally shift hard enough to chirp the tires on the 1-2 shift at full throttle?
Metal typically sinks in the pan and you won't see it on the stick
converter failure is not totally uncommon, even at stock power level.
If you have a failed converter...you would be much braver (or riskier) than I if you installed the trans with only a new converter.
