TH350C with high stall
I cannot find much info online about anyone using a high stall lockup converter
I have found that TCI makes a 4000ish stall with lockup clutch for the TH350C part# 242422
I really would like to have the lockup function for highway cursing without having to build a 700r4
Engine is a carbed Lq4 going in a 72 trans am
So I know its a long shot but has anyone ever used the Th350C ? From what I gather they are IDENTICAL in strength to the non lockup TH350s
I obviously wouldn't be using the lockup while under heavy load
thanks
TCI are typically recommended to be avoided.
There should be no difference in strength.
Check with CircleD and Yank to see if they have anything to accomplish what you want.
Might call around those and ask I was just hoping to not spend a fourtune on a converter! lol oh well gotta pay to play I suppose
They may be much less expensive but why spend money and time twice.
CircleD and Yank (and FTI is brought up many times) build you a convertor and then ship it to you.
I have searched ALL over and contacted all the major torque converter makers.
these are my only options for a 10" lockup converter for a TH350C
Engine will be a Lq4, 243 heads, MS3 cam 3.08 gear (might swap to 3.73 depending on how loose converter is)
Car is a 3500lb 72 firebird
Hays Twister ------------------- 3000 stall $450
TCI Super street fighter-------3600 stall $507
Hughes GM35L -----------------3500 stall $630
Hughes GM35LHD-------------3500 stall $685 (doesnt say the difference in these 2)
Obviously with my VERY limited budget the Hays looks very tempting BUT I cannot find any reviews on ANY of these converters in a TH350C
So if anyone has anything bad OR GOOD to say about any of these brands please let me know!
One previous post above mentions avoiding TCI, I have heard some good from them at my local track but dont know how much to trust them lol?
I will not be using the lockup under much power, just while cursing so im not concerned with the strength of the clutch much.
thanks again
-Dalton
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
I thought I contacted FTI maybe I missed that one
looking for something in the 10” size around 3500rpm or higher stall speed
also I will not be using the lockup under much throttle I will only be using it just for cruising
thanks
anyway, This converter can be easily done with one of our billet converters. shoot me a PM or call at the shop for more info.
-Dalton
1-866-726-8358
FTIPerformance.com
