4l60e rebuild gone wrong
no trouble codes,
After starting out, it shifts into second fine, but it never shifts into third, just stays in second. Reverse works fine.
Any idea where to begin troubleshooting? (only tried running it on jack stands so far)
Used a scan tool and can see the computer commanding third, but it just stays in second forever.Shifts back to first fine when coming to a stop.
All gears shift smoothly and fine, did some WOTs, etc, all looking good.
The TCC definitely locks, but it seems to unlock with not much throttle. Any slight hill and it appears to unlock.
I took it for a drive with tech2 - The TCC duty cycle increases where it should, but only up to 90%. Even when i command TCC lockup, the duty cycle will only go up to 90% (I have retained PWM functionality). When its locked, the TCC slip speed varies from -30ish to +150ish. I also see P1870 intermittantly, but no check engine light.
I have installed the Sonnax oversized TCC regulator valve. The P1870 is new since rebuild, so I assume I have done something wrong. ANy suggestions appreciated.
What did you use for assembly lube?
Did you presoak the clutch plates?
I'm glad your saying 90% is fine, but the reason I assume(d) its not enough, is because of the p1870 code. - though its not tripping the check engine light, and seems to be intermittant.
1. Installing a larger spring which essentially bypasses the PWM functionality.
2. Installing an oversized valve from Sonnax to retain the PWM fuctionality.
I went with option 2. Reamed the boar out and wet air tested it prior to installing the valve body - All was perfect.
So I can safely eliminate the TCC regulator valve as the cause. I think that leaves me with the Actuator feed valve, or a leak on the input shaft. I wet air tested the actuator feed valve and it passed (prior to install), so the only thing i can think of is a leak from the input shaft. I'm sure I installed the o ring correctly, but there was some where on the input shaft spline - do you know if wear on the input shaft spline could cause a leak in the TCC circuit?
I am more than willing to tear the transmission back down, but i'm not confident enough in my troubleshooting steps to do so. I'm not really inclined to pull the trans out, replace the input shaft and seal, and re-install the transmission without having a more valid troubleshooting analysis, which is why i think i'm way over my head at this point.
I've done extensive research into the PWM circuit, and a leak at the input shaft is about the only thing I can think of.
