Update: fti 3800 reg hit? No lock up.
Hahaha, ah shoot.
Pt4000 was a click away and I couldn't do it.
Fti 3800 hard hit vs soft hit I need to get straight. I can't make sense of which is more like the pt4000. I thought the 3800 hard hit had a 2.35 str, the soft hit I have no idea. I'm getting confused because I'm reading the pt and hard hits are the best of the best NA converters. I figured ftis 3800 hard hit would be a bit less loose than the pt4000 with my 3.73s. I'm going to guess the 3800 hard hit is better at the track than the ss3600?
no title here
I will say this, I have a Yank SS3600 in my Trailblazer and it is too tight. I actually talked to Dalton today' and recommended the 4000 Hard Hit. With my SS3600 ai can't 60' better than a 1.8 in my Trailblazer and I have more than enough power and suspension. So I am building a LQ9 with a cam, CNC 243 heads, and a Fast LSXRT that's going in my GMC Yukon. That SS3600 is tight enough that I think it will be perfect in there. I seriously doubt you'll be satisfied with the times from the SS3600
I don't have experience with FTI but I doubt you will be disappointed with any of the 3 converters you are looking at. Absolute worst case scenario, if need be, you can pull it back out and have it restalled/tweaked.
The first time you go wot you're going to be floored at the difference. Especially with you having a cam.
Along with better 60'/ off the line, the shift extensions will also put a massive smile on your face.
It's hard giving converter recommendations because everyone's driveability and sensitivity to looseness is much different. With you having 3.73's all 3 of those converters will drive very nice.
LS1Tech Sponsor
Not being familiar with what Yanks part numbers translate too in terms on fin angle, fin count, stator etc, this is a hard one to answer. OUR popular 3600 option that is the go to for guys looking for a good balance of street and strip performance is a soft hit converter.
Unless you are used to driving a stalled auto and prefer the looser street manners of the hard hit converters then i would go with a soft hit converter since you are doing more daily type driving than racing.
-Dalton
-Dalton
The 0086 is the popular the 3600 i was referring to. The SRLT or SRLS is what determines which input shaft the converter is for. The 8082 you mentioned is the 4000 hard hit that is going to have looser street manners.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
![](https://ls1tech.com/forums/signaturepics/sigpic99412_4.gif)
hard hit=PT
soft hit=SS
correct dalton??
@FTICONVERTERS
Hard hit has lower STR than soft hit
PT has lower STR than SS
Hard hit not good for power adder
soft hit ok for power adder
PT not good for power adder
SS not good for power adder
correct me if I'm wrong here boys! haha
soft hit=SS
correct dalton??
@FTICONVERTERS
The 7082(3800 hard hit) has a 2.35 STR. The 3800 soft hit would be a 6391 has a lower STR and has some different characteristics that make it work really well with power adder combos and N/A combos that need a looser converter for racing while still giving some good street manners.
Hard hit is SS, and Soft hit is PT.
Yanks Power adder series 3800 is around 2.2-2.3 Im told.
The PT4000 is 2.2, PT4400 is 2.5 (according to their chart)
LS1Tech Sponsor
hard hit=PT I don't know Yank's numbers and how they translate to fin angles, count,and stators so i'm not sure to be honest.
soft hit=SS
correct dalton??
@FTICONVERTERS
Hard hit has lower STR than soft hit No-Hard hit means higher STR, less efficient. soft hit means lower STR, more efficient
Hard hit not good for power adder for common setups yes, there's always combo's that don't follow the norm.
soft hit=SS
correct dalton??
@FTICONVERTERS
keep in mind as you know that all this bench racing is relative to the combo it belongs to as well. What works for customer A could be miles off for customer B unless all variables are identical.
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
^^^ Post # 29, that sort of agrees with what I put in post #2. The SS series has a slightly lower STR than the PT. OEM convertors are considered hard hit but unfortunately they're only 1800. The SSs' grab at rated stall immediately and remain tight thru-out. The PT series is softer because it has some slight slippage when hitting rated stall.
SSs' have high efficiency, PTs' less efficiency but not by a lot.
#32
^^^ I dont think thats right lol, ss4400 has a higher str than pt4400, just like the hard hit 3800 has a higher str than the soft hit/reg 3800
I think the soft hit 3800 is closer to a PT3800 and I think while soft hit sounds boring, I need that one lol.
Boring sounding stall to go with my boring sounding "hot cam" lol. Pro thruster sounds cooler than soft hit...gotta say it lol.
Its like FTI builds pro thrusters as their regular converters if my thinking is correct.
#33
All of this brand mix-up has me confused.
Higher STR is *generally* better suited to a naturally aspirated setup. It will be more loose and flash to the stall rating then the torque multiplication will "hit hard" and you'll be in the powerband.
Lower STR is *generally* better suited to power adder setups and is more "street friendly" because it won't feel so loose down low. The lower STR means power adders won't "blow through" the converter as easily
I have a lot of quotes and asterisks in there because those are rough generalizations.
PT=lower STR
SS=higher STR
Hard hit = Higher STR
soft hit= Lower STR
I hope that's more clear...more like mud now rather than like pitch.
Thanks for clarifying Dalton!
PT=lower STR
SS=higher STR
soft hit= Lower STR
#34
I've had both the SS3600 and the PT4000. Both drove very differently and have their pros and cons. The SS3600 was tighter around town with my 3.73s and broke traction with ease on street tires at all times. Car felt really torquey with it, was nice and I often miss it. PT4000 is loose as hell so sometimes annoying with my car being so loud and it feels much more sloppy than my SS3600 around town. However, the PT4000 pulls noticeably harder on the highway, has a much nicer shift extension. In a perfect world I would have two cars one with each. I have been saying for years I wants to go back to my SS3600 but there's times I love the PT4000 so I've yet to do it. Depends what you're after. For a daily driver the SS series or equivalent from FTI would be my recommendation. For a weekend warrior either will do but up to your preference on loose vs. tight. I suggest riding in someone's car before you take the plunge if possible. I recently took my LT1 to the track, just a 359rwhp car. Cut a 1.56 60' on 275/40R17 Nittos on my stock wheels so the PT4000 will still launch hard. I actually like that it's more controllable on the street when punching it at slower speeds versus the tight SS3600 which just punished the tires. I really had/have a love/hate relationship with both converters depending on the day because neither is perfect 100% of the time. There's give and take. A PT3600 or PT3800 would be an intruiging choice if they'd make one. I once asked Yank for a hybrid between both my SS3600 and my PT4000 converters and they suggested their PAS3800. Would like to learn more about that one but doesn't seem like many people run it.
Edit: In conclusion, SS3600 is tighter and more enjoyable during normal driving and mild to moderate hot ******* around but leaves a little to be desired at WOT. PT4000 is a top end hero but is a loose sob around town which can be annoying with a loud car and annoying if you like that instant torque feel. SS3600 going to be better choice for most people but not all. PT4000 is a little more of an acquired taste, a little more of a gamble if you will. If you have a DD or your tolerance levels aren't high the SS3600 is more ideal. If you have a higher tolerance level and/or you want max NA performance at the track the PT4000 is more ideal. All my opinion of course. Both converters are awesome just in different ways.
#35
PT=lower STR
SS=higher STR
soft hit= Lower STR
PT=lower STR
SS=higher STR
soft hit= Lower STR
I agree with everything you said....but...
To add more confusion...
The ss converters are listed as being safe with power adder and the pt are listed as best n/a converter according to yank.
As you said the pt has a lower str than the ss, yet the ss can be sprayed, meaning high vs low isn't completely accurate for n/a setups lol.
I'm ordering a 3800 regular converter from fti and calling it a day. I do believe fti got it's good name because it's basic stall is more like yanks pt series. Obviously that will get you results.
The pt4000 seems like too much for me, the ss3600 seems too tight. The ss4000 I assume has the same top end efficiency problems as a ss3600. I think the fti 3800 is exactly what i need. Looser than the ss3600 yet not a pt4000 loose, but also has the good top end efficiency the pt series has vs the ss.
This is all just educated guesses and my understanding of yanks str chart vs what people have reported in posts I've read. I hear the ss3600 is 95% efficient up top, stock converters are more efficient and have lower str. I'm betting the pt series is more efficient than 95%. But none of this is an Apple's to Apple's comparison.
It's a weird thing to try and grasp, and I have to use yank as examples, but I'll be buying the fti because I can get a converter and trans cooler for the price of the yank.
#38
Be careful that you guys do NOT overdue it with one of the "Hard-Hit" Torque converters.
A lot of guys like the loose, then kick in the pants feeling that is obtained even with a low powered engine...
But be warned... these loose/ less efficient torque converters will cost you horse power up-top.
Let the guys at FTI guide you in the right direction...
But the high RPM HP pull with a more efficient converter to me blows away the kick-in just above stall speed with a loose converter!
#39
That makes me feel better. Cant wait to get this thing in, hopefully over labor day weekend or before. Got 5 days off. Probably just start on it on a Friday night and be done by Saturday afternoon. I do need to find a trans cooler, thinking b&m supercooler but not sure if theres something else out there.
#40
![](https://cimg0.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/screenshot_2016_09_19_11_58_57_d2193f5e3d8e627c24c4ceb25fb359676c05784c.png)
![](https://cimg2.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/screenshot_2016_09_19_11_58_34_44f712830df0cbf5e32335489c1c84af414de5bf.png)
