Update: fti 3800 reg hit? No lock up.
Old 08-14-2019, 08:00 PM
  #41
Kfxguy's Avatar
i put a Hayden 679 on mine with no other changes it dropped from 210-212 degrees to less than 180. I put a fan on it and it stays under 170 now.
Old 08-14-2019, 08:10 PM
  #42
FirstYrLS1Z's Avatar
To 98CayenneT/A, where did you mount/install the cooler ?
Old 08-14-2019, 08:15 PM
  #43
98CayenneT/A's Avatar
I deleted my a/c so my cooler is right where the a/c condenser goes. spaced 1/2 in. from the radiator.
Old 08-14-2019, 09:14 PM
  #44
trilkb's Avatar
Thanks for the parts list.
I will retain a/c plus I run a fast toys ram air kit. So mounting it under the front bumper will work nicely I think.
Old 08-20-2019, 06:57 PM
  #45
trilkb's Avatar
Stall showed up! Looks so....plain and black...lol. it did come with some weird coupler...never seen that before. Any ideas? I'm assuming the bolts are meant to replace factory ones. Do they need loctite?
Old 08-20-2019, 07:11 PM
  #46
I use just a small dab of blue loctite.
Old 08-22-2019, 09:03 AM
  #47
trilkb's Avatar
Cool. Gotta figure out this crank index thing as well. My plans to install it this weekend may not happen. Got birthdays and crap to go to.
Old 08-22-2019, 10:44 AM
  #48
LS1Tech Sponsor
FTICONVERTERS's Avatar
Just slide that collar on the converter and you should be good to go. If you want to double check fitment, check the converter with no transmission against the flexplate. We do the converters this way so that they can fit both long and short cranks.
-Dalton
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 08-25-2019, 11:06 AM
  #49
thm_som's Avatar
You will like it ! FTI,Yank,CircleD in 3600,3800, 4000, 4400, they're all good convertors. And they see their use with gears of 2.73, 3.23, 3.73.
Love the combination of my SS4000 with 3.73’s!
Old 08-25-2019, 12:47 PM
  #50
^^^ that's a very good / best combo. 4000 to put it up in the powerband and 3.73s' for a good torque increase when it does hit the 4000.
Old 08-25-2019, 06:59 PM
  #51
vorteciroc's Avatar
Received 1,263 Likes on 882 Posts
You guys must be discussing this in reference to stock or mildly modified Gen III/ IV SBC engines...
There are many builds/ engines that start making a little power and would end up having way too much stall-speed with a torque converter like that.
Old 08-26-2019, 11:44 AM
  #52
trilkb's Avatar
Almost went with the SS4000 lol, hell I think it was in the cart at one point and I almost hit buy, but than the PT4000 was the same price and I thought long and hard about it too.
The following users liked this post:
thm_som (08-26-2019)
Old 08-26-2019, 12:34 PM
  #53
LS1Tech Sponsor
Trilk, have you run the new converter yet?
__________________
1-866-726-8358
FTIPerformance.com
Old 08-26-2019, 02:54 PM
  #54
trilkb's Avatar
Not yet, Going out of town Thursday and didnt want to leave the car on jack stands blocking my driveway. I also injured myself again at work on Friday (was going to start then) so I am waiting a week or 2 till I start to feel a little better so I can hurt myself again while doing this lol. Ordered a true dual exhaust too that I want to get put on at the same time. Still need the trans cooler too lol.
Hopefully within a month the car will be good. Being hurt sucks, just jacking the car up is a feat. Hopefully i can get a run in before winter too.
FTICONVERTERS (08-26-2019)
Old 09-04-2019, 10:02 AM
  #55
trilkb's Avatar
It has begun. All I got done was getting the exhaust all off which was a nightmare, nothing would slip apart at the slip joints. Got the drive shaft ready to come out but once again it's stuck in the rear axle. Always fun doing stuff in the driveway.
Old 09-05-2019, 06:48 PM
  #56
trilkb's Avatar
Well, tonight was more successful. Just down to bell housing bolts and the 2 trans lines and she's out. I'll be very happy to use the supplied bolts over the gm Allen head bolts. Apparently last time I half assed it because those things broke loose with one hand, I won't lie....sorta glad about that lol.
Old 09-05-2019, 07:01 PM
  #57
Thing will feel like you added well over 100 whp your first wot pull.
Driveway work on jack stands definitely sucks. I still work off jack stands all the time but in a garage and it's definitely a massive pain....... not to mention when you roll under the car then realize you forgot the wrench you originally rolled out for
Old 09-05-2019, 08:11 PM
  #58
trilkb's Avatar
Lol yea. Since I'm already hurt I'm really thinking things through before I get under it. I am using a 1" piece of foam insulation to lay on. One side is slick which helps, it's light weight so easy to move, and provides cushion for my shoulder blades.
Front of the car is up 4" higher than the picture. May need to go higher still.
100hp sounds like what im looking for lol. Can't wait to get the true duals on too and hear them.
Old 09-07-2019, 02:42 PM
  #59
trilkb's Avatar
Ok, so the FTI is in, but not bolted up to the flywheel.
I felt 3 clicks, and currently the converter to flywheel spacing is about 1/4" or 3/8ths, could be less but I'd say 1/4. So my plan was to shim it 1/8th so it doesn't pull out of the trans. But hey I've already learned I've done stuff wrong in the past lol. Good idea?
Fti supplied 3 bolts but they are quite short. They may work. Oh, and the spacer went in lol.
2nd question...i pulled the trans pan and did a filter, but I can't get the filter collar piece out of the trans to replace. What's the trick? I don't want to mar anything up going at it with a pick. Seems like it needs to be hit at the outside edge to crush it inward?
Old 09-07-2019, 05:18 PM
  #60
bbond105's Avatar
If the old seal is still pliable I don't change them. Compare it to the new seal.
Quick Reply: Update: fti 3800 reg hit? No lock up.
