Built 4l65e vs boost
Old Nov 8, 2019 | 07:21 PM
  #121
Jays_SSZ28's Avatar
I could care less about all the transmission builders. I've never had a built 4l60e. All my experience is on BONE STOCK 4l60es and they never broke regardless of the power, tire, or leaving the shifter in D while racing. This cost $0. Racecar? Sure build the trans to the hilt to hold more power than you make, makes sense. Streetcar and don't want to spend money or lose overdrive or shove a 4l80 in? TM FTW.
I'm running out of popcorn and advil.
Old Nov 8, 2019 | 07:26 PM
  #122
ddnspider's Avatar
Try Midol instead
Old Nov 8, 2019 | 07:35 PM
  #123
Game ova's Avatar
You guys are wild!
Old Nov 8, 2019 | 08:15 PM
  #124
Jays_SSZ28's Avatar
Try Midol instead
Clearly I have *****. I actually run a 4L60E with zero TM, three actually, not a problem with any.
I just wear the maxi pad for the day one comes through the floor, cuz we all know it's any second now.
Old Nov 8, 2019 | 08:19 PM
  #125
Jays_SSZ28's Avatar
Deleted torque management
Old Nov 8, 2019 | 08:32 PM
  #126
ddnspider's Avatar
They ain't that big if the 4L60e ain't stock
Old Nov 8, 2019 | 10:31 PM
  #127
vorteciroc's Avatar
This is by far the greatest input drum and sun-shell related failure I have seen!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
AMAZING!!!
THM400/ 4L80E center support/ intermediate clutch explosions look very similar in terms of sheer violence/ case explosion!
Old Nov 8, 2019 | 11:18 PM
  #128
gjestico's Avatar
What happened there. The alum input housing/drum looks to be vaporized. Only thing left is steel input/sun shell. sorta. Failure point ?
Old Nov 9, 2019 | 03:23 AM
  #129
sjsingle1's Avatar
well thats a new way to take the tranny apart
Old Nov 10, 2019 | 05:39 PM
  #130
Bspeck82's Avatar
No reason to turn torque management off. Learned quite a lot about it recently actually from a discussion with some tuners in high hp turbo applications. One, it's easier on parts and two, some people need it because they make enough power to be extremely dangerous without it. I seem to remember asking my tuner about it because people here said to turn it off and he laughed and said no, I'm not turning it off...and that's in a 400hp car.
Old Nov 10, 2019 | 07:44 PM
  #131
Kfxguy's Avatar
be careful what you say. Next thing you know the internet “professionals” will tell you to find another tuner. Lol.
Old Nov 10, 2019 | 07:46 PM
  #132
Jays_SSZ28's Avatar
You need to find another tuner.
Old Nov 10, 2019 | 08:28 PM
  #133
Kfxguy's Avatar
Told you.
