4l60e shift kit install advice
Old Jan 24, 2020 | 06:33 AM
  #41
Adrian Aiello's Avatar
Originally Posted by MaroonMonsterLS1
Transgo 7-cs spring kit...do NOT screw with the capsule in the input drum.
Drive a 2nd sun gear bushing in on top of the stock bushing (so there will be 2 stacked bushings) into the sun gear.
Out of curiosity. Why don't you mess with the capsule on the input drum? Does installing the transgo one cause an issue?
Old Jan 25, 2020 | 12:32 AM
  #42
PBA's Avatar
PBA
I am not a fan (a word that I hate) of the capsule being removed. When using the feed holes I recommend, I have never had a problem with the capsule. If you go over 7,500 rpm, then there is a better way of doing this. I can explain what I do if you need to know for going over 7,500 rpm. The TransGo bleed off orifice they supply does not remove all of the oil that can accidentally bring on the 3-4 clutches at hi-rpm in the top of first or second gears. Leave in the capsule. Just make sure that the ball seats in the capsule.
Old Jan 27, 2020 | 05:56 PM
  #43
MaroonMonsterLS1's Avatar
I'm with PBA
If you are going to change the capsule, superior K070 is the way to go
Here's a couple things to do to avoid centrifugal apply
DO use the 5 batwing springs around the 3/4's
If you really want to, you can put a 4r70 direct steel on top of the spring retainer to add some additional preload. I've only found that helpful in very high RPM setups
Old Feb 26, 2020 | 04:47 AM
  #44
Hey guys I've put the transmission in the car and put 100km on it so far. Drives great so thank you all for your input and advice. I know it turned from a shift kit install into a rebuild so I appreciate all the help.
Only problem I have with the build so far is intermittent flare or bind up maybe on the 2-3 upshift under light to medium throttle. Very random but when it happens i can see rpm jump maybe 200 RPM on tacho.
Noticed the servo cover has a little bit more travel then specified. Can I throw a transgo shim in it or should I buy a new pin? I'm sure 1 shim will get it to spec.
Anything else I can try if problem still present after I adjust pin travel?
Oh I should mention at light throttle the 2-3 shift is smooth and barely noticeable and under heavier throttle it's quick and crisp. I haven't WOT yet cause obviously it's a fresh build. I've Also tried driving with fluid slightly over full level with no difference
Old Feb 27, 2020 | 03:40 PM
  #45
took out the superior 4th piston and billet cover out and put stock back in as shims don't work with the big piston. Had to put both shims in and pin still just out of spec so guess I will be buying a new pin to get that clearance closer to the .060
Am I on the right track? Would this would the small flare up. Still would appreciate any input on anything else I should check that would cause that random little flare. Could it be in the tune?
Old Feb 27, 2020 | 04:23 PM
  #46
Jays_SSZ28's Avatar
Add some more 3-4 return springs.
Old Feb 27, 2020 | 07:44 PM
  #47
I'm sure you got a few spares from all the ones you threw over the shoulder
I actually opened up my original box already. Only damage was burnt band + drum and a well worn seperator plate. The 3/4 clutch was still alive after all the abuse and that had the clutch return springs fitted 😉
Old Feb 27, 2020 | 09:33 PM
  #48
Jays_SSZ28's Avatar
So the transgo springs and the stock return springs?
An adjustment/calibration problem should be consistent, an intermittent problem is not a good sign. Intermittent usually gets worse.
Just keep driving it, you built it right thanks to the step by step instructions provided here. What could possibly be wrong.........
Old Feb 27, 2020 | 11:22 PM
  #49
It's consistent if I get the throttle and load under the same condition every time but not every shift happens under the exact same condition
Just need some advice on things to check not get trolled. If box has to come out to fix something it's a lesson learned but personally I think it could be the servo clearance or feed hole problem.
I'm confident I did a good job on the internals. All seals and clutches felt nice and air tested all good
I though maybe even the tune and shift adaptation might be out since I drove car around for like 6 weeks with no 2nd gear
Old Feb 28, 2020 | 06:09 AM
  #50
Jays_SSZ28's Avatar
You say it jumps 200 on the taco. Thats actually quite a flare on a new build. So what have you learned through all this?
Ok I'll tell you. A flare on the 2-3 is the band releasing too soon OR the 3-4 applying to slow/late.
So you need to get the band to release sooner.faster and/or the 3-4 to apply sooner/faster.
How do you make all that happen? You make the band (servo) hole smaller, and/or make the band clearance bigger, and/or make the 3rd apply bigger, and/or tighten the clearance on the 3-4 clutch. This is ASSUMING everything is built properly. Do a pressure check, this will tell you if it's fucked up or needs a calibration change like mentioned above.
I don't know if a commodore has shift adaptives but you should under no circumstances be driving it without those being reset, that's like putting the old fluid back in it.
Old Feb 28, 2020 | 02:33 PM
  #51
I tried to reset TAP data but according to my scanner adapt shift is disabled and all the tables don't show a value. Possible the tune has been locked by the workshop, I'm waiting to hear back from them.
I will try make band release hole smaller
I remember PBA mentioning in a few posts that tightening the servo pin clearance actually increases the speed of 2-3 hydraulic apply works.
when you say make band clearance bigger isnt that the opposite. I thought that would cause the band to release slower and 2-3 clutch to apply slower simultaneously
Old Feb 28, 2020 | 03:53 PM
  #52
I still can't figure out what you don't like about these "batwing" springs in the drum
The stiffer transgo springs help resist centrifugal apply, and return the piston when the 3/4's are off...the 5 perimeter springs help the apply plate move away from the pressure plate. Ensuring that the clutches don't drag
Also, we could get into the dynamics of fluid fill vs pressure vs piston travel but I think that's a little out of the scope of this thread.
I see those 5 springs as possibly helping, definitely not hurting, so why not
Old Feb 28, 2020 | 04:03 PM
  #53
Hahaha please don't get him started on those return springs. I just want to fix my flare at this point and he will fight you tooth and nail about those springs 🙄
Old Feb 28, 2020 | 04:12 PM
  #54
Remind me again of the following.
  • 2-3 feed hole size
  • band clearance
  • 3/4 clutch clearance
  • what ratio servo for the 2nd gear portion (vette?)
  • any mods to the servo accumulator area? Slots in the steel cover, additional spring in there, etc
  • Have you verified fluid level
  • Have you checked line pressure
Old Feb 28, 2020 | 04:49 PM
  #55
Jays_SSZ28's Avatar
Possibly? LOL
IOW may or may not be doing anything.
Old Feb 28, 2020 | 04:50 PM
  #56
  • band clearance
all work I done were as follows
Frebuild kit
-all borg Warner frictions and band
-hd2 kit and spring kit ( installed everything except valve in input drum and didn't modify the piston in reverse drum but everything else done as per instructions)
-transgo seperator plate and torlon check *****
-sonnax hd 2-3 shift valve
-checkball capsule in case replaced
-removed checkball from rear capsule in case
-corvette servo with modified spring retainer as per PBA instructions. Installed springs from HD2 kit in servo
-stock 4th servo and cover
-4th accumulator blocked with checkball
-2nd accumulator modified as per PBA instructions
-3-2 valve blocked inboard
-r&r input shaft and sealed with Loctite
-rebuild pump and installed transgo high rev kit and transgo boost valve
-new sprags HD
-sleeve reinforcement kit on input drum
Seperator plate drilled as per hd2 kit except
1-2 .098 (9" stall converter)
2-3 .137
3-4 .137
Band .098
3-2 .117
Band clearance is over spec .150 ( I'm waiting for a sonnax long pin to be delivered from another state)
3/4 clutch pack clearance was about .030 wet from memory ( I've been looking for the paper I wrote down the clearances on)
Fluid level good, I overfilled a bit and problem still there
Haven't checked line pressure. Need to buy a gauge still.
Old Feb 28, 2020 | 04:55 PM
  #57
Jays_SSZ28's Avatar
Yes you are correct.
I had a 2-3 bind up problem once that I never figured out, Dana at probuilt had no definitive answer after a 1+ hour phone conversation, transgo couldn't help either. Maybe I was reliving that nightmare.
Old Feb 28, 2020 | 05:04 PM
  #58
Jays_SSZ28's Avatar
This would be my diagnosis. This will make the band release before the 3-4 applies.
You know this subconsciously because you caught it when I said increase band clearance.
Old Feb 28, 2020 | 05:07 PM
  #59
Clearance was tighter with the superior 4th piston and cover but still above spec. I tried to put shim but discovered they don't work with the bigger pistons so tried stock cover with Shims but still out of spec. Might try welding a blob on spare pin just to test the theory
Old Feb 29, 2020 | 04:06 PM
  #60
Welding a blob and grinding to fit is the best way.
Very rarely do I have a stock pin get band clearance right where I want it.
I'm welding and grinding the pin on almost every build...even stock stuff.
