4l80e rear band damage
Old Jun 8, 2020 | 04:08 PM
truckdoug's Avatar
Default 4l80e rear band damage
can anything other than a bad install cause the band to pop off the lug and do this?
Old Jun 8, 2020 | 07:31 PM
vorteciroc's Avatar
You can double check that the 2 anchor pins in the case for that band have not moved.
I do not see this hardly anymore... but in the THM400s it was more common.
Old Jun 9, 2020 | 04:41 PM
truckdoug's Avatar
pins look well anchored and at the same depth. It really looks like that part of the band was forced past the pin when the rear assembly was set in the case.
also there was roller out of place in the OD drum, looks like it just skated around leaving funny marks here and there, without really any major damage.
fwiw, i bought this trans in a 3500HD truck i parted out. I was told the trans was new GM reman and the engine lost oil pressure (bad oil psi sensor).
I shouldn't be salty i suppose. Selling the 10.5 " AAM dually axle paid for the truck and I ended up making >1000whp on that stock bottom end.
Old Jun 9, 2020 | 06:06 PM
vorteciroc's Avatar
How were the end-play measurements on this unit?
Too much end-play?
Old Jun 9, 2020 | 08:43 PM
clinebarger's Avatar
Looks like someone misinstalled the band? Parts would damn near need to be missing for endplay to be that far off. You can see the angled wear/witness mark on the band. Sonnax sells a Output Reluctor to save that Output Carrier assuming it's otherwise okay?
Did this unit have reverse?
Old Jun 10, 2020 | 12:55 AM
vorteciroc's Avatar
I have not seen Sonnax offer the out-put speed sensor reluctor in a long-time.
Where are you finding them?
I kept one because I thought they were discontinued.
Old Jun 10, 2020 | 01:08 AM
Bought one from WIT not to long ago.
Old Jun 10, 2020 | 05:27 AM
truckdoug's Avatar
yes the unit had reverse. the only symptom this trans had was an incredibly harsh 1-2 .
not sure what the rear assembly play was, I didnt think to check while disassembling.
i got the tone wheel on ebay. sonnax 34477A
