4L60E Build
Old Mar 27, 2022 | 09:58 PM
  #341
weinerschizel's Avatar
Anybody have these bore plugs stick before? I got another valve body here and cannot get out the Converter Valve the plug is stuck. It will slide partway out then the second part of the bore plug (inner) catches on outer bore of case.
Old Mar 28, 2022 | 07:27 AM
  #342
2BFAST's Avatar
Yup. Soak it liberally with WD40. Let it sit. Then work at it. Dont get rammy
Old Mar 28, 2022 | 08:25 AM
  #343
MaroonMonsterLS1's Avatar
Drill a hole in the end
thread it for 10-24
install a screw, grab with vice grip, tappy tap tap with a small hammer
replace with a sonnax o-ring end plug
make sure you clean the bore up once you get it out
Old Mar 28, 2022 | 10:19 AM
  #344
bbond105's Avatar
thread it for 10-24
That's the way I do it.
Old Mar 28, 2022 | 11:41 PM
  #345
Got the bore plug out. Thanks! Valve body is all rebuilt.
Curious, the donor transmission is from 2005. Harness is green circular version. This is going into a 2001 Chevy Tahoe with my original P01 PCM.
Will this harness / connector be compatible?
Found a post HERE slowly trying to digest it so I can figure out if female (PCM) side of harness is compatible / pinout is same or reverse compatible.
13 Pin 2005 4l60E connector from donor transmission
Old Mar 29, 2022 | 12:19 AM
  #346
tayto's Avatar
https://ls1tech.com/forums/automatic...hangeable.html
this thread can answer your question along with the other handful of 4L60E interchange posts that have popped up today.
Old Apr 1, 2022 | 05:51 PM
  #347
Awesome, I ordered a harness. It's Rostra 350-0061. Linked here: Manufacturer's Webpage & instructions
The TCC lockup solenoid doesn't have a provision to lock in the filter screen. It's a different style from factory. Anybody know where I can get a filter screen for solenoid?
No provision to lock in the filter screen / doesn't fit all the way in.
TCC Solenoid filter screen from kit
Old Apr 1, 2022 | 10:41 PM
  #348
bbond105's Avatar
I it didn't come with a screen I wouldn't worry about it. I run them all of the time without it.
Old Apr 2, 2022 | 10:26 AM
  #349
If I ever have a problem do I risk metal shavings going through the rest of the transmission?
I looked quite a bit and seems they are all making earlier style solenoid that has screen filter in case. Or does this have a screen built into it somewhere?
Old Apr 2, 2022 | 07:54 PM
  #350
tayto's Avatar
the screen protects the solenoid, not the transmission. the 700 tcc solenoids never had a screen FWIW.
Old Apr 3, 2022 | 11:30 AM
  #351
Good to know. I wondered if the solenoid was large enough for debris to pass through the orifice. Thanks!
Old Apr 9, 2022 | 05:44 PM
  #352
All the pieces are put together! Minus haha a pan gasket and the filter. Curious, my pan is missing the magnet. Is there somewhere to get pan magnets from?
Also there's no dipstick limit bracket. I'm assuming this newer pan style doesn't need that?
Old Apr 9, 2022 | 08:12 PM
  #353
tayto's Avatar
I got my pan magnets from rockauto.
Old Apr 28, 2022 | 08:35 PM
  #354
Got caught up in work again. Just now able to resume my project. I'm getting ready to swap the transmission into my truck. Curious if there's any little last minute checks I can do with it assembled.
I was double checking the sprags were installed correctly... Which way should I be able to spin the input and the output? And in which gears?
1,2,3 forward sprag?
not sure how output sprag works from perspective of case. facing rear of case I can spin the output shaft counter clockwise.
Any other sanity checks as it will be in truck hopefully by end of next week.
Old May 10, 2022 | 05:25 PM
  #355
Transmission is in the truck. Each week I get a few hours where I can work on it... Hopefully will be spinning it soon! I just need to reinstall exhaust, driveshafts, hookup and torque down transfer case, put fluid in it, and lastly a little tuning before I can run down the road.
Anybody know what specs are on the bolt for bracket that routes fuel lines & harness?
It's really small, I seem to have lost it... M8 x 1.25? No clue... It's not super critical but I need to get a bolt for there when I go to ACE next.
Old May 12, 2022 | 11:12 PM
  #356
Well it's in and works like a champ. Between work (I'm self employed, two businesses, and three jobs) and ordering parts took WAY longer than I'd ever hoped.
In full disclosure, I didn't modify the valve body. I know we had a heated debate on that here but had my reasons, and is simple enough to change mind on / build another valve body. I'm glad I didn't modify the valve body. It shifts like it means it, quickly and firmly. Maybe a bit too firmly but I think I can dial that down in the computer / tune.
Pulls a bit differently off the line. I assume because of torque converter. I got a Circle D 278.
Anyways, some closure to this really long post. Thanks everybody for the tips, conversation, and participating.
Now I'm onto a steering gearbox and transfer case build
Old May 13, 2022 | 12:52 AM
  #357
matermark's Avatar
Great job Weiner! Drive it a while & let us know if anything changes.
It'll take me a while to decide on a few things before I get mine together, as I'm being--well--no cooler or lines threads!! I wanted to do a thread about the $5 fitting I made, but it may have to wait. But I had a guy who delivered my Walmart groceries ask if I wanted to sell the XUV. I asked if he knew what it was and if he knew what the roof does and he said YES. When I told him I'm rebuilding the trans and deciding on the lines he asked who's doing the install & I said I don't have anybody yet. He says his bro-in-law did that for a living but got laid off recently, so I may have someone to R&R it, but I'd want to be there when it goes down. He said I can pay when the job's done....
Hope yours stays together for a million miles!
Old May 13, 2022 | 10:09 AM
  #358
bbond105's Avatar
I'm happy that it worked out to your satisfaction. I took you a while but you stuck with it, good job.
Old May 13, 2022 | 01:45 PM
  #359
@bbond105 thanks man. Was a really fun project. I hope to someday to a build video on my truck but I'm CONSTANTLY busy trying to run business. I've done a bunch, nearly completely dismantled everything right down to the radio and rebuilt it. Last remaining items to build are the steering gear box and the transfer case. Then I'll have rebuild or replaced all systems on the truck.
I have a C5 Corvette that's been neglected though. It needs a little work, I keep fidgeting with this truck haha. Corvette is lightening fast. It's awesome. Anyways, thanks for all the awesome help.
Old May 13, 2022 | 01:49 PM
  #360
I have the largest Tru-Cool cooler on my shelf in the garage. I too need to install it. I saw a post somewhere where they take the old cooler line, cut it, turn it around and quick coupler connect it. Apparently it works. I think you can find that post if you do a google search. Otherwise PM me. I don't like connects and would want to braise line for one solid line. I also didn't like placement in that post. Otherwise, it came with rubber lines you can use, which are pretty simple to rig up.
On another note, transmission temperatures. They were very similar to the transmission I removed so I think a cooler is important / would be helpful for sure. I just need to find time to get mine on the truck.
