4L60E Build
TransGo 46PLT96 Specs:
https://res.cloudinary.com/transgo/w.../46-PLT-96.pdf
https://transgo.com/product-details/46-plt-96/
The TransGo kit is better than just jacking up the pressures with HP Tuners. You have come this far why take the easy way out now? The valve body is what will define how well your transmission will work.
I'm still sitting here looking thinking this over... I looked at 2BFASTS post on 4L60E build. Who here has built more than one transmission?
Uh...really?
even if you have hptuners...physically altering the valve body to have on/off lockup is superior to just tuning it for 100% pwm lockup
pwm lockup relys on a feedback bias on the valve and will never achieve the same feed of line pressure into the converter as you achieve with the flipped valve.
I've had this discussion with many other shop owners and operators. They have a vehicle giving them issue, converter codes, slips, etc.
They tell me "well it can't be that...I've tuned it for 100% pwm, can't be the issue"
I bet them $1...tell them to flip the valve or install a *fitzall* type valve...they do...it's fixed.
As for the rest of the valve body and pump...there are things that cannot be fixed in the tune on a 60e. Shift timing in the 60e is only altered by the pressure control solenoid. That's it.
ECM will increase or decrease pressure to alter shift feel
but...if you have a shift timing issue such as band release and 3/4 clutch tie up, or flare, etc that won't be fixed with a tune. You need to alter orifice sizing and springs etc in the valve body to properly remedy or alter the shift feel.
The pressure the pump can achieve has a physical max limit no matter what the tune does. You must change physical parts to be able to achieve more pressure.
So on and so fourth.
If this could all be magically done in the computer...we wouldn't be discussing the intricacies of valve body modification on this forum
I hired a shop to help me with some odds and ends. They have experience in both tuning and building 4L60e for high power applications. They are strongly advising against TransGo parts / valve body modification. I can definitely see he's talking about at the shop.
https://ls1tech.com/forums/automatic...cer-plate.html
https://ls1tech.com/forums/automatic...l#post20367385
https://ls1tech.com/forums/automatic...2-3-shift.html
https://cimg7.ibsrv.net/gimg/ls1tech...8a5521304b.jpg
I'm going to use the other valve body. Not even the TransGo ISO-CONV valve fit right in the donor transmission valve body. It wiggled too.
The spare valve body is from a 2007 transmission (according to casting mark on top) the other is from a 2003. Worm tracks look the same so assume it's fine.
It's your trans. Do whatever you want. But it has been explained to you that a tune CANNOT change certain things. It just isn't physically possible. But hey...if you wanna spend your money and chase that dead end with them...be my guest
Only thing pending is pin-less Sonnax accumulators which I asked Dana about. I'd prefer pin-less and kit came with pinned. Description says it comes with one pin-less and two pinned. He'll get me taken care of.
