Trans cooler help
Cooler has two ports..
Trans has two lines
Where do i connect the feed and return to? Lol like all these posts (if you follow them word for word) they are saying to unplug the top line from the radiator then put a fitting into that port then connect the two "lines" together and that blows my mind... sorry if anyone can barney style this for me. That would be great. Also the trans feed/stock cooler/radiator/aux cooler/return thing confuses me too.
Found this, so pretty much i leave the top port and line alone, and just introduce the new aux cooler to the return port and line... wow if thats the case, why didnt all the posts just say that lol?
The image pictured above does not appear to depict 4L60E cooler flow/routing.
So, what I did (and described above) was to splice into the upper (return) line at the point where the factory rubber hose connects to a hard line with a removable clamp (near bottom of engine bay). Remove clamp, pull off rubber hose and install a double barbed fitting into said factory rubber hose (I believe it was 3/8"?), then connect one of the aux trans cooler rubber lines to the other side of that barbed fitting (I used fuel injection style clamps on both ends of the barb). Then, the other rubber line coming off the aux trans cooler would connect to the factory hard line (which is now exposed, since you removed the factory clamp and hose to install the barbed fitting), which is already flared, and you can either reuse the original factory clamp or another fuel injection style clamp. So the trans fluid now runs through the factory cooler, into your aux cooler, and then back into the trans.
I never actually removed the factory line from where it threads into the radiator at any point to do this, so there is no "open port". I just disconnected said line down lower, where it's is clamped, and spliced in there. I hope this better explains the setup.
The only reason why you should have any "open ports" to cap off on the radiator is if you wanted to completely remove the factory trans cooler from the circuit.
I know some folks like everything to be threaded, but I've had no problems using the barbed fittings and FI style clamps on mine for the last 18 years.
Hayden Automotive 678 Rapid-Cool Plate and Fin Transmission Cooler
It will be a 3600 stall.
However, I really like the LPD in hotter climates or for those who is bypassing OEM cooler.
For example : tru-cool 4589
LPD Stands for low pressure drop. What it basically does is lowering the pressure and oil flow in the radiator itself and brings it back on the output.
What it does is the oil stays more time in the radiator and the airflow cools it way more efficient.
LPD is a monster of a cooler solution.
