Rebuilt 4L60E issues. Finally fixed!
Old May 30, 2022 | 01:32 PM
  #41
bbond105's Avatar
Originally Posted by atlsoldier27
so the two main issues now are the fluctuations in RPM when at speeds of 45-60 MPH. Seems as if torque converter is slipping or something. I’m not sure if that is the case.
You can check if it is the TCC applying and releasing by lightly applying brake pedal. If RPMs stop fluctuating, there is a problem with TCC. A worn TCC bore in the valve body can cause this. A Fitzall TCC valve will fix this most of the time.
the other issue is when applying gas from start, the pressure and RPM raises, but the transmission hardly reacts until it reaches over 90PSI, at which I feel it somewhat jump into gear. As if a band or something is not being applied correctly
Low line pressure at low RPM seems to be the problem. Will need a scanner to continue diagnosing.
See answers in red.
Old May 30, 2022 | 01:38 PM
  #42
bbond105's Avatar
the other issue is when applying gas from start, the pressure and RPM raises, but the transmission hardly reacts until it reaches over 90PSI, at which I feel it somewhat jump into gear. As if a band or something is not being applied correctly.
Do you have this issue in reverse also?
Old May 30, 2022 | 02:04 PM
  #43
atlsoldier27's Avatar
the same issue is in reverse, as far as not getting a direct result of pushing the gas/slow engagement.
Old May 30, 2022 | 02:16 PM
  #44
bbond105's Avatar
That is also from what seems to be low line pressure at low RPMs.
Old May 30, 2022 | 02:20 PM
  #45
does the PR valve have any effect on this?
Old May 30, 2022 | 04:55 PM
  #46
bbond105's Avatar
Yes, PR valve regulates max line pressure and EPC solenoid regulates the line pressure that is needed for engine load. Engine RPM also has a lot to do with line pressure. As you can see in the test with the trans unplugged, the higher the RPM the higher the line pressure.
Your pump and PR valve seems to be making adequate line pressure but for some reason it seems the PMC or EPC is bringing the pressures down to low at low RPMs.
Old May 30, 2022 | 05:19 PM
  #47
as far as EPC, there is no way to test it without scanner? I have the one I pulled off of it after rebuild. I could test it somehow if it’s possible.
Old May 30, 2022 | 10:32 PM
  #48
bbond105's Avatar
I don't think that testing with an ohm meter is 100% conclusive. I may be wrong in that statement, but I would really like to see the output to the EPC change and see how that effects the line pressure. You have had 2 EPC solenoids in the trans with the same results. So, what are the odds of both having the same defect.
Old Jun 1, 2022 | 07:28 PM
  #49
mrvedit's Avatar
Moderator
Mr Bond is giving you excellent advise.
Your line pressures while unplugged are good; you can absolutely rule out a PR valve problem. The idle pressures first seemed a bit lot, but they my car idles at 900rpm, not the 600 you likely have.
I would:
1. Try another EPC solenoid. If that doesn't fix it:
2. Disconnect the MAF. This switched the ECU to "speed density" mode. Its a bit risky but just avoid WOT. If this fixes it, then your MAF is bad.
3. Last resort, turn the EPC screw to give you the pressure you need. Yeah, this is covering up some other problem, but it gives you a working car without tearing apart the trans.
Old Jun 2, 2022 | 12:50 AM
  #50
bbond105's Avatar
If you do turn the EPC screw, be sure you turn it clockwise.
Old Jun 2, 2022 | 07:04 AM
  #51
I would:
I have Disconnected the MAF sensor before while running and the truck stalls out. Is that normal? I will buy a new EPC and give it a try to make sure I didnt receive a faulty one. I will also replace the forward accumulator due to it being loose.
Old Jun 2, 2022 | 08:38 PM
  #52
mrvedit's Avatar
Moderator
I would not expect the engine to stall when disconnecting the MAF, but I have NO experience with a 1997 PCM. Perhaps someone more experienced will chime in here.
If it is normal for the engine to stall, they we will have to hope that the MAF is OK.
If it is NOT normal for the engine to stall, then we have a clue. I would make sure the MAP sensor is connected. Generally an LS engine will run as long as it has the MAF or MAP sensor. (Of course ideally both.)
While you say the problem started after the rebuild, the trans removal/install might have damaged a sensor/wiring or left something disconnected.
Granted I'm grasping for straws here, but also trying to keep the conversation going.
Old Jun 3, 2022 | 05:25 AM
  #53
I will dig around at this today as I’m off work. I also have a scanner for the day. I will see what all I can find with it and post everything I can.
Old Jun 3, 2022 | 08:36 AM
  #54
mrvedit's Avatar
Moderator
Great. Yes, a scanner that shows MAF and MAP values would be useful; even better if it shows the EPC current. (Your symptom corresponds to the EPC current staying high and not changing.)
I know you said you checked the trans fluid level, but for future people reading this, let me review it:
The correct way to check the trans fluid level is with the engine and trans warmed up and with the engine running! The fluid should then be at the "hot" line.
You can make an approximate level check with the engine cold and off -- the level should be about 1-1/4" above the "hot" line.
(In other words, when the engine starts, the level goes down because the trans pump fills the upper parts of the transmission and the torque converter.)
If the trans pan is ever off, it is a good idea to check the accuracy of the trans dip stick - the "hot" line match the the line between the trans body and the valve body.
Old Jun 3, 2022 | 10:23 AM
  #55
i have some images I’m throwing on this post of my finding from the scanner. I don’t know what my readings should be at all. I unplugged MAF and started it up and no change at all. Truck idles the same and going into gear feels the same (jerking motion). Not sure if that is an indication of the MAF being bad. It has been cleaned with the proper cleaner as well.
Graph of MAF and MAP at idle
MAF and MAP and 1500RPM
EPC while idle
TPS and MAP info at idle
EPC while in drive and at ~1500 RPM.
Old Jun 3, 2022 | 08:18 PM
  #56
mrvedit's Avatar
Moderator
Nice. You did great with that scanner.
The MAF and MAP values look normal. And good that you were now able to start and drive with the MAF disconnected; that actually indicates that the MAF is good.
The EPC current changed from 1.06A to 0.18Amps. That is a bigger drop that I expected but good. We can now rule out problems with the MAF, MAP and PCM.
If the scanner is still available, the next step is to correlate the EPC (PCS) current with your trans line pressure. There should be a smooth correlation - changing from e.g. 60psi to 200 psi as the current goes from 1Amp to 0 amps.
If the pressure stays at e.g. 80 psi as the current drops and then suddenly changes to 200 psi, then likely the EPC or related valves are sticking and need attention.
Hopefully we are getting close now. I think and am hopeful that the problem is in the valve body.
Old Jun 3, 2022 | 08:37 PM
  #57
Thank you for that input. I was starting to think I was getting further from an answer with those values. I will try what you asked with the stead rise of both and see what happens. After done with that, I will get the valve body back off and take all valve out to see if I can find any stick valve.
Old Jun 3, 2022 | 10:29 PM
  #58
mrvedit's Avatar
Moderator
Lets not go disassembling valve bodies just yet. With the line pressure versus EPC Amps info and perhaps guidance from some of the experts here, hopefully we can pinpoint the problem.
Old Jun 4, 2022 | 01:35 AM
  #59
vorteciroc's Avatar
Wow!
I think Bbond105 and Mrvedit deserve a round of applause for "Taken Care Of Business" while the Forum is a Ghost-Town.
I am kinda sad to see such little activity on the Forum... But we all have lives.
And it is not like I have been on the Forum recently either...
Mental Health... I am learning at a very steep gradient, is a Real Bitch!
Anyway, what Year and Model is the Vehicle being discussed?
The Unit is of a 1997 Model-Year, correct?
Is the PCM also?
These Early-PCMs were not terribly fast in terms of Processing...
Line-Rise in response to Throttle-Input was rather slow.
Including the older PCMs; this is where discussions of using a Vacuum-Modulator came from.
What is the Torque-Converter that is being used?
Depending on the STR and Stall-Speed; unwanted behavior may be exacerbated.
Cooler Circuit Temps and Pressures would be nice to have.
Hopefully this information will be more commonly monitored in the future...
(with Line-Pressure and Sump-Temp) like we monitor our Engines.
At this Point; an ATF Pressure-Gauge needs to be taped to the Windshield...
A Friend/ Passenger is needed to watch EPC and TPS data...
And lets see how things look actually during the unwanted behaviors!
Old Jun 4, 2022 | 02:08 AM
  #60
Wow!
Is the PCM also?
appreciate the input, you are right that they deserve that if not more for their time and help.
the vehicle is a 97 k1500 5.7 V8 with a 97 PCM. I have though about trying the popular “411” PCM swap, but a lot of trouble to go through right now. And the converter info is a bit “here say”. I do know that the builder put a high stall converter in it at first, around 2000. At which I told him was wrong and he changed it out for me free of charge. As far as I can tell now, the stall is around 1400.
as far as getting certain data, I’m not sure if it’s the scanner or something else, but a lot of data tables show as “N/A”. Like temperature. I noticed that there is a section that says “hot mode” that kicks on. It’s in one of the photos I posted. I will have to try what you said as far as trying to watch EPC/TPS data while the issues arise. Today is my last day with the scanner.
