4l60e binding reverse
Old Mar 19, 2024 | 09:16 PM
  #221
Mbs1994's Avatar
Soaked clutches, built the new reverse drum, installed everything including the band on the pin lol, put the pump in, walked away feeling good. Two seconds later I realized I forgot the spring cage in the reverse drum so ripping it all out tomorrow. I'm not even upset because I still made progress and it's all still learning and every time I redo something it's faster next time.
Old Mar 21, 2024 | 08:34 PM
  #222
Mbs1994's Avatar
Making more progress. Got the valve body back together minus the one broken bolt, installed the forward and reverse abuses, got the bell housing back on minus the one broken bolt, and started dialing in the band. Still need to run the wiring for the temp gauge and get a different cooler that will fit "dope style" with shipping time on my bolts might not be done till weekend after next. Just another thank you to so many of you guys for the help in this.
Old Mar 22, 2024 | 09:31 PM
  #223
Mbs1994's Avatar
Figure I'll just keep updating till it's done. Wasn't feeling it much today but still got my dash taken apart, probably too much, to run wires for my temp gauge. Bell house bolt should be here tonight so thinking I'll go and work on it tomorrow and hopefully mount everything. Still waiting for my replacement valve body bolts and my new trans cooler but that should be the last of it.
Old Mar 22, 2024 | 10:37 PM
  #224
vorteciroc's Avatar
What is this "dope style" Cooler?
Old Mar 23, 2024 | 10:49 AM
  #225
Mbs1994's Avatar
It's instead of mounting the cooler in front of the radiator you mount it underneath the front of the car. I'm eventually going to run the ssra and honestly I didn't want to undo everything to mount it the more traditional way.
Old Mar 24, 2024 | 08:02 PM
  #226
Mbs1994's Avatar
Transmission is mounted but not fully bolted down. Trans cooler should be delivered tomorrow, gotta flush the lines again, finish the temp gauge, and reassemble everything else. Probably won't be back at it till Wednesday with the weather taking a bad turn.
Old Mar 26, 2024 | 08:58 PM
  #227
Mbs1994's Avatar
Trans is bolted fully, drive shaft, o2s, cross member, exhaust, and cooler are all mounted loosely. Waiting on the valve body bolts and a new pan, gotta connect the torque converter, flush the cooler lines, connect the aux cooler, starter, interior harness, and funny to me but I can't finish the gauge because I can't open the door far enough to get to the fuse panel.
Also for anyone that does stumble into this mess if you are built like a twig like myself you can at least start the top bolt by hand and then ratchet it in from there.
This should be done shortly. Thank you all.
Old Mar 27, 2024 | 02:57 PM
  #228
Mbs1994's Avatar
I broke the oil level sensor right at the connector. Shipping is far out and local is over priced. Is this something I can rip out a junkyard 5.3/6.0/lsx?
Old Mar 27, 2024 | 04:14 PM
  #229
vorteciroc's Avatar
Post a Photo of the Connector, and your Location.
I can build you a "Pig-Tail" for Cost (usually about 75% cheaper than the Prices you are seeing for Retail).
That offer goes to any member here for Connectors!
I always have offered a Professional Courtesy to other Professionals...
AS well a discounts to Automotive Enthusiast!
It seems to be rare these days... I guess most People can't or won't offer this in today's Market.
It's sad.
Old Mar 29, 2024 | 05:37 PM
  #230
Mbs1994's Avatar
Oooooooooooooh BABY is it GOOD to have my car back. The transmission is all done and it feels fantastic. Thank you all so very much in 200+ response thread. You guys are all strangers and don't have to help and here we are. I couldn't have done it without you all and it is so very much so appreciated
Old Mar 29, 2024 | 05:54 PM
  #231
FranksCustomTrans's Avatar
LS1Tech Sponsor
Gear and glad could help in any way I did ,
__________________
Old Mar 29, 2024 | 06:33 PM
  #232
bbond105's Avatar
I glad that you got it. I was beginning to think that you weren't going to be able to get it working. Congratulations!!
  #233
Mbs1994's Avatar
You helped out so much from Start to end. Thank you frank
Old Mar 29, 2024 | 07:40 PM
  #234
Mbs1994's Avatar
Lol you and me both! Going back and reading through man was it a struggle but in that same breathe I learned SO much and feel like this isn't even that bad to do anymore thank you also sir for all your help.
Old Mar 30, 2024 | 05:16 PM
  #235
bbond105's Avatar
You're welcome, Frank carried the load on this one.
